Help! Setting up new F/Xi A6 Surrounds
Igo
Igo Posts: 411
edited November 2008 in Speakers
I can't believe I have to ask this.
I have just opened the box for a new pair of F/Xi A6 surrounds. These speakers are going to be mounted on the wall behind me about a foot behind me at 4 feet away. The label, as I'm reading it, suggest the bass driver is actually pointed away from me and on both sides of me, only the ported side with the solo tweeter will be facing me. Can this be true?
...Link to my System Showcase...
"ES - Kind'a simple but I like it"
Sony ES STR-DA4300ES 7.1
Sony ES SACD SCD-C2000ES
Sony 400 Disc CD CDP-CX455
Infinity BU-2 Sub-Woofer
Polk Audio RT800i Towers
Polk Audio CS400i Center
Polk Audio FXiA6 Surrounds
Sennheiser HD 280 Pro Headphones
DH-Labs T-14 Speaker Cables
Panamax Max 500 DBS Line Conditioner
Panasonic TH-50PZ85U 50'-Plasma
Play Station III - BluRay
Logitech Harmony 550 Remote
Logitech diNovo Mini Keyboard
Post edited by Igo on
  • WilliamM2
    WilliamM2 Posts: 4,782
    That's the way it is with the older Rti's like the fxi30, so it's probably correct.
  • Igo
    Igo Posts: 411
    My RT7s are too intrusive on stands behind me but I want surrounds for Ht and yet I want rear speakers for SACD. I guess I'll have to try switching them to see how they work for SACD which means the drivers can't be pointed to the outsides. If they won't work it's back off to the dealer.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Yes , thats true. I also own the FXI A6's and I just reversed them (woofers facing each other). Play around with them and see what sounds best.
