Insane bass
Sherardp
Ive been talking with Grimster on this, but I want to get opinions from the club. Lately Ive been pondering back and forth for a new toy, was thinking the Ultra but shipping kills to Japan. So I've been thinking about adding dual PC-NSD12s to my dual PB12/PLus2s. OH my, I'm thinking this should be killer in my dedicated room which is 14x22. Any thoughts, overkill, a waste, crazy, what do you guys think?
Post edited by Sherardp on
Never overkill when it comes to adding more thump to so much already.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
If you have room, more subwoofers are just about always better than a single large one.
Spreading the subs around the room makes it very hard to get peaks/nulls from standing
waves. The only drawback is that the smaller ones don't go down as low. However, with the multiple drivers, you can always eq the very bottom up a little without blowing anything up- just use caution and be realistic about where your subs roll off.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
A single ultra is supposed to be close to dual PC+/2's... I would hold out for an ultra (or two) rather than go with a lower end (for SVS) subwoofer.Mains.............Polk LSi15 (Cherry)
