Where can you get Blade/Blade connectors?
ben62670
ben62670 Posts: 15,969
edited March 2011 in Vintage Speakers
Anyone know where to get just the ends?
Ben
Ben
Post edited by ben62670 on
    SCompRacer Posts: 9,112
    edited November 2008
  • ben62670
    Awesome. It is saved.
    Thanks Again!
    Ben
    Ben
  • awe-d-o-file
    awe-d-o-file Posts: 146
    ET
    System: MF Trivista SACD > Placette passive> CJ passive horizontal bi-amp> MF 2500A(LF) MF2100(HF) > 1.2TL's
    Other: Speltz silver Eichmann IC's & speaker wire, Econotweaks Detail Magnifiers, PS Audio P-300(source), R. Gray 600, Al Sekala's AC R/C filters, R. Gray HT PC's, Oyaide R-1's,WPC-Z , M-1, Herbie's & DIY Isolation
    Room: Qty 7 - 4' tall 18" diam. bass traps, Qty 4 - 4' X 2' X 4" panels. All DIY - man my wife is tolerant!
  • bikerboy
    bikerboy Posts: 1,231
    Hi Ben,
    I needed a set and was looking at suppliers but wasnt sure which ones to order. So I called Polk CS to ask what type to order and they sent a set at no charge. Best CS ever!
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • ben62670
    Excellent:)
    bikerboy wrote: »
    Hi Ben,
    Polk CS Rocks:) What I want to do is make some high grade cables for Polkies so I will need to be able to order them up;)
    Ben
  • awe-d-o-file
    ben62670 wrote: »
    Excellent:)
    becoming the SDA interconnect guy. I think you should just add it to your existing "line" of cables. For pin/blade remove the proper blade and insert the RCA "pin" from this RCA connector. It's an unscrewable connector where the pin part is separate and it easily accepts solder. They're kind of expensive since you don't use most of it but they are perfect for the job, try one and see. Good luck!
    RCA @ PExp: http://www.partsexpress.com/pe/pshowdetl.cfm?Partnumber=091-400&FTR=091-400&CFID=14289545&CFTOKEN=77796255
    ET
  • ben62670
    edited March 2009
    Bump for a friend.
    Ben
  • thsmith
    thsmith Posts: 6,082
    edited March 2009
    Looks like Ben has a new project or 2
  • ben62670
    edited March 2009
    thsmith wrote: »
    Na A friend was looking for some ends. There are a few good links here to share;)
    Ben
  • ben62670
    edited March 2011
    Another Bump for a Polkie.
    Ben
    F1nut Posts: 51,797
    edited March 2011
    You could simply provide them a link to a particular thread like the rest of us do.
  • ben62670
    edited March 2011
    Or I could bump this thread so if someone has found a better source it could be added to this thread.
    Ben
    Ben
