5.1 to 7.1
I need help with speaker set up. Just upgraded my receiver to an Onkyo 606. I would like to add the additional two speakers, but my problem is the set up. I currently have my rear speakers directly behind me with no space, the sitting is right up against the rear wall. All of my current speakers are boston accoustics and I would like to add the OWM3's. Is it required to have spacing between the sitting area and the rears? Would it make sense to add the additional two speakers and get the full affect? Would love to upgrade but placement may be a problem.
Post edited by bronxmimi on
Space isn't a necessity if isn't a possibility IMO. However if you have space restraints, it won't benefit you much to upgrade to a 7.1 from a 5.1. I know it is the nature of the beast in all of us to upgrade, so if you feel the need to then the only thing that is going to soothe that itch is to upgrade. I have a 7.1 receiver (806) and only run 5.1 because of similar room size restraints. As far as speaker layout THX has a good one, I have enclosed a link. One note, that according to THX's site in a 5.1 system the surrounds are supposed to be to your left and right, not behind you. The speakers don't appear behind you until you move up to 7.1. Happy listening and welcome to Club Polk.
http://www.thx.com/home/setup/speakers/71.htmlHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Thanks for the quick response. You are correct, I had the itch to upgrade to 7.1. The 5.1 setup is working just fine for my size room.
I tried a 7.1 setup.....
For my size it was overkill. 10x15
I have my 6.1 all set and it sounds pretty damn sweet.
*Actually it's a 5.1 for now cuz I've yet to hookup a #6 just yet*
IMHO you hafta have a pretty good size room to appreciate a 7.1 or better setup. EX: 20x20 or larger
Yamaha RX-A710 90Watt 7.1
Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
Music CD: Sony CDP-CE375 5 Disk
HD TV: Vizio 42" LCD 1080p E420VO
Blu-Ray: Sony BDP-S350
DVD: Sony DVP-NC665P 5 Disk
AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
Phones: Sennheiser HD280 Pro -
You are right. I have a 19x15 room and the 5.1 works just fine. You know us audiophiles, just want more.
Bigger speakers and a bigger sub always works.
Unless your like me and have very limited space.
(Sniffle.....I miss my 10b's)
I do have it in mind to get a set of RT25i's or RT35i's and make my RT15i's sats. :rolleyes:
Something I learned over the years.....speakers are what make a system not the receiver.
A mediocre receiver can sound as good as a 1k+ receiver with some real nice speakers and nice thumper!
Thats not entirely true. A $400 receiver with $5000 speakers or even my speakers won't do them justice and probably would do them more harm if anything. Great speakers need great electronics to sing.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
Yes , it is the beast in us to which is forcing upgrade to 7.1 . I am running 5.1 setup with monitor (60,30,cs2,psw125) and quite happy. But after upgrading to Onkyo 705 , I don't think that anything ,other adding two monitor 30 for rear, is going to satisfy me.
