Need a subwoofer cube?
You're in luck with what I found on CL!
The critter I am selling is a cube shaped "SUB". It measures 15^3" so that means a cube with a length of 15 inches on each side. On each of the 6 sides is an 8" sub driver speaker, totaling 6 speakers @ 200 watts @ 8ohms RMS each. Total power consumption is 1200 watts, this thing is very intense at full power. Each speaker has a 16oz permanent magnet with a 2" dual voice coil. Each speaker has 4 push button type wire connectors, 2 for each voice coil. The cube itself is matte black and not really that pretty, it has an 8" hole in the center of each panel. The speaker themselves are gloss fire engine red, with "inverted dust covers" that are brushed finished aluminum with the same gloss fire engine red. The wire is 18 gauge industrial speaker cable, all voiced are wired straight, no cross over. Requires at least a 8ohm 1200watt amplifier set to mono output. This thing is about 75 lbs of raw audio carnage. It is rated for cars, home, parties and or driving people insane. If your into saying "look at my huge speaker of destruction" this it. I am selling it at my cost of the speakers, it could have a price of over $500 in a specialty shop. I have no use for it, I live in an apt building and this surly would get kicked out if not arrested if were to ever use it, also I no longer posses an amplifier that can power it. I have a custom heavy cardboard box for it. So I hope someone can make good use of it, have fun going deaf.
http://seattle.craigslist.org/see/ele/931819588.html
