Reprise: The $50 speaker-wire question
EFanning
The question is: Will there be a noticable sound quality difference between the two speaker wires used in the set up listed below?
It's Belden 5100UE from Westlake Electronic.
Or, it's Remee speaker wire from eBay
Both will be employed as 60-foot lengths of 14-gauge in-wall wire. The wire will power Polk M30s in a kitchen and be connected with a late-1990s Yamaha 80W per channel receiver.
The main difference (if Remee is reputable) appears to be number of strands in the wire. The Remee has a bit more strands. The Remee is slightly cheaper.
Marantz DV4001 CD and DVD
WD TV Live Hub with 1 TB (Need DacMagic)
Marantz PM7001 Integrated amplifier
Philips GA 312 Turntable
Polk Monitor 70s (Zone 1)
Polk Monitor 40s (Zone 2)
