Speaker testing software?
Where could I find software to test speaker FR without spending a fortune?
One that aids in crossover design would be a plus.
TIA,
Mike
TIA,
Mike
Post edited by Face on
TIA,
Mike
What about this software from Partsexpress. I never used it before but the majority of the reviews were favorable.
http://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=390-804
MikeSDA SRS 2.3TL's
SDA 2B TL's -
I would need something for higher frequencies, thank you though.
Test tones and a radio shack SPL meter will only get me so far.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Are you talking about something that directly connects to a speaker like the woofer tester at PE but full range? Or something that measures with a mic in the room like REW?____________________
Pool: Atrium 60's/45's -
REW that goes full range."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
http://www.interdomain.net.au/~bodzio/
http://audio.claub.net/software/jbagby.html
http://www.ijdata.com/justMLS%20manual.pdf
http://www.libinst.com/LspCAD.htm
and this one http://www.libinst.com/see Praxis.
You will also need a good soundcard and calibrated mic.Testing
Testing
Testing -
Perfect, thanks!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
forgot about this freebie for xover design.Steep learn curve but very good. http://www.speakerworkshop.com/Testing
Testing
Testing -
I'm not sure if this is frowned upon but 15 years later I have the same question. I'm looking for recommendations for testing software and a calibrated microphone to test my speaker performance. I've built a few subwoofers as well as upgraded the crossovers in a pair of Warfedales and completely re-did a pair of Polk bookshelf speakers. I'd love to see how they measure in my livingroom. (Whether or not I can do anything to improve how they measure is another story- but you have to start somewhere right?) I don't have a PC laptop so it would have to be MacOS or iOS compatible. Any recommendations?Yamaha RX-A2080 HT Receiver in 5.4.4 configurationYamaha A-S2200 Integrated Amp Powering an extra set of Front SpeakersAudioLab 6000N Network Streamer Connected to Spotify and Amazon HD Music4 10" Subwoofers Powered By Dayton Audio 1200 DSP Amps4 In ceiling Atmos SpeakersSpeakers:Warfedale Diamond 9.1 (Front and Rear L+R)Polk Monitor 5 Jr+ (Front L+R)Martin Logan Motion SLM XL (Center Channel)Subwoofers 2x Dayton Audio RS270-8 10" Reference WooferSubwoofers 2x Dayton Audio RSS265HO-44 10" Reference Series HO DVC Subwoofer
