Surrounds to go with my SDA II's
Driver_King
Driver_King Posts: 266
edited December 2008 in Wanted (WTB) Classifieds
I'm interested in getting some surrounds to go with my SDA II's. Right now, I'm using some Realistic Minimus-7 bookshelves with custom DIY speaker mounts. The mounts are so strong you could probably get an attachment and post up a couch, so weight isn't an issue.:D
Price is though. I was going to get some Monitor 4's until the deal fell apart. Deals always seem to fall apart for me if it wasn't meant to be. :o Anyways, I was interested in maybe some Monitor 10's for surrounds. I was looking for something with similar characteristics as my SDA II's (two SL1000 tweeters, three mid-range drivers, 12" sub radiator). I want the panning and soundstage and detail to be up to par with my SDA's. I do know that I don't want true SDA's as surrounds as they are too big and the cancellation involved. I do want some vintage Polk Monitors though.
Also, if anybody has a really good deal on vintage amps that provide good, clean power for the SDA's and possibly the soon-to-be surrounds, that would be great. I couldn't care less in what condition the speakers are. As long as it is cheap and useable, I will go for it. And I know how that sounds- I am a cheapskate.:)
I also heard about Monitor 10 upgrades?:confused: Is that worth it and does it work? Recommendations for my SDA II's for cheap upgrades and tips would also be greatly appreciated! Sorry for the long post by the way.:p
Home Theater:
Onkyo TX-SR805
Behringer EP2500 for SDA's
Polk SDA II fronts
Polk Monitor 5Jr. surrounds
Polk Monitor 4 back surrounds
DIY A7-900 and DIY A3-300
Post edited by Driver_King on
  • Driver_King
    edited November 2008
    Any help?
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
  • george daniel
    george daniel Posts: 12,096
    Do you have the SDA SRS II's or Sda II's,,an upgrade to either would be the RDO replacement tweeter, but you'll need to put a $ on what you mean by cheap.The tweeters are 48.00 each.Polk used to have,and may still have a HT setup/voicing guide on the main webpage for matching vintage speakers in the HT environment. I can'y help much in that department,as I'm a L&R person. Good luck. Oh, check the FM for amps that may suit your needs. Good luck,and welcome to the forum.
  • Driver_King
    The SDA II's, not the SRS speakers. And by cheap, I mean less than $200 for the Monitor 10's, preferably less than $100.
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
  • Driver_King
    Bump.
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
  • Conradicles
    Conradicles Posts: 6,119
    Where are you located?
  • ben62670
    ben62670 Posts: 15,969
    Where are you? You most likely won't find monitor 10's for under $100. You may want to look for 5's, 7's, or an RTA of some sort.
    Ben.
    Ben
  • Driver_King
    I live in St. Pete, FL.
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
  • Driver_King
    What are the differences between the Monitor 5, 7, and 10?
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
  • ben62670
    Ben
  • Driver_King
    This is a subjective question but which would be best for a small room for surrounds and a good match for my SDA II's. It seems that I can get the Monitor 5, 7, or 10 speakers so my options are pretty open.
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
  • ben62670
    5's are real good as surrounds due to their smaller cabs.
    Ben
  • Driver_King
    Bump. Still looking for a good price on a pair of Monitor 5's in any condition.
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
  • Driver_King
    Nobody has a pair?!?
    Home Theater:
    Onkyo TX-SR805
    Polk SDA II fronts
