Have a 4.1 system, looking for right center channel. VM20?
sulifromcali
Hello all! First post, didn't even know this forum existed, so much awesome info.
I am looking to buy a center channel. Here is my setup:
2 RTiA7s as my fronts
2 RTiA3s as my rears
DSW Pro 500 Sub
Harman Karon AVR-347 sub
I want to get something sleek to hang below my wall mounted LCD.
Do you think the VM20 is a good option for center? That is the one I have my heart set on. Some input from you guys would be great.
Also, I might want to switch to the FXi series for my rears. We don't listen to music, so it'd be for movies and cable tv.
DSW Pro 500 Sub
Post edited by sulifromcali on
You really want your center channel to be from the same line as your main speakers. In your case, that would be the CSiA4 or 6. (the 4 would be smaller)
If you really do not like the looks of the CSiA4, you could always keep running in a 4.1 configuration like you are now.
I do not think the VM line would be a good match at all. (to the point I think it would sound better without a center channel like you have now.)
any suggestions for the small space i have between my TV and the stone on my fireplace??i have about 6.5 inches of space. here is a picture of my setup:
http://i31.photobucket.com/albums/c363/njesco24/photo3.jpg
i work at fry's electronics and the audio guys were emphatic about me going with the VM20 saying it would blend well..guess not -
That poor bird.
If the VM isn't a good blend, are you able to return it?
I'm also for the idea of 4.1, in most(not all) cases, center channels are over rated."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Aw shoot the bird put him out of his misery:eek:
I agree go without a center plus it will sit way to high unless you are using tall seats.;) Man I would get a crick in my neck looking up at that TV:)
Welcome to the forum.
Jim -
All for the 4.1 and if that is not an option go for a matching center with your current speakers. And if those guys at fry's told you you would be fine with the VM then they need to find a new job IMO.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
That poor bird.
I don't think I can return it, but I will be getting a good deal, only $150 for brand new one.
I think I need to readjust my receiver. I am not getting a swirling surround sound effect when I watch movies. People with crappier setups have a better sounding system then mine. I thought maybe the center was the missing piece. I don't get real good separation of sound. I'm using a Harman Kardon 347 -
Check to make sure none of your speakers are out of phase."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
