Thanx for the Sub Help Guys!
Motzart
Motzart Posts: 1,075
edited November 2008 in Speakers
Gotta love this place!
After careful consideration....and your suggestions didn't fall of def ears....
But I went back with something I'm familiar with....Velodyne!
You woulda too!
I got a spanky new Velodyne DPS-10 in box when it was all said and done for $225 shipped!!
Paypal sent me a 10% off coupon offer and this one I found on Evilbay was BNIB $250 shipped -10% offer = $225.
Now that was just too hard to pass up!!!(MSRP was $499)
I thought maybe it was an old model but the manufacture date is Dec 27,2007 not old at all.
I had a CT-100 for a number of years and loved it.
Sold it in the Spring after it sitting for 4yrs.
Over the Summer I got a brainy idea to get another system setup.
Oh well I'm sure I'm not the only one that's happen to? :rolleyes:
This DPS-10 is 185watt RMS and my old CT-100 was 150watt RMS.
So I did get a lil upgrade....as well as lil better digital processing which does produce a lil cleaner thump! :D
My Polk PSW120 is a very nice lil unit but it was time to upgrade to just a tad more punch.
Thus it being up in the forsale area for a new Polkie home. :)
Just curious.....how many others here have a Velodyne and what wattage/Model?
Yamaha RX-A710 90Watt 7.1
Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
Music CD: Sony CDP-CE375 5 Disk
HD TV: Vizio 42" LCD 1080p E420VO
Blu-Ray: Sony BDP-S350
DVD: Sony DVP-NC665P 5 Disk
AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
Phones: Sennheiser HD280 Pro
Post edited by Motzart on
  • Lowell_M
    Lowell_M Posts: 1,660
    I have the CT-120. Not sure of the wattage....somthing like 250 maybe. I've been pretty happy with the output, but it is slow and has a lot of port noise. At the time that I bought it I didn't know what I was doing at all and it was the best sounding sub that Circuit City sold by far. I paid a rediculous $450 for it which is sickening considering what you can get for those $$'s used.
    It hits hard and has nice rumble but is WAY too slow for music. I don't hate it enough to upgrade just yet...but I'm getting close. I almost bought one of the PSW1000 refurbs the other day.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • Motzart
    a_mattison wrote: »
    I have the CT-120. Not sure of the wattage....somthing like 250 maybe. I've been pretty happy with the output, but it is slow and has a lot of port noise. At the time that I bought it I didn't know what I was doing at all and it was the best sounding sub that Circuit City sold by far. I paid a ridiculous $450 for it which is sickening considering what you can get for those $$'s used.
    Yeah with todays new technology and DSP the sound produced is much tighter and responsive!
    CT series is about 8yrs old IIRC and things have come a long way in that time.
  • Ron Temple
    Ron Temple Posts: 3,212
    The DPS 10 if played within it's limits is a very tuneful sub. Make sure you calibrate it, then leave those front blinking light volume buttons alone. One good thing about the sub is that it plays much lower than it's specs indicate. However, distortion goes way up and the driver goes into distress at high volume on content below 25hz. So don't run it too hot. It will be a very nice sub for you.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Motzart
    Ron Temple wrote: »
    Please elaborate on "Calibrate"
    Something I've never tried before.....actually never heard of it till I got on this forum. :o
  • Ron Temple
    Setting speaker size, distance, crossover and volume level matching between your speakers and sub using the test tones and a Radio Shack SPL meter. Audessey or other auto setup/eq versions will do it, but there are usually errors.
    It's not hard, takes about 10 minutes to do it manually and you then have a balanced system. The DPS volume control is wonky. You never know where you are relative to any scale. You want to get the sub balanced with the mains and then leave it alone.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Motzart
    Yeah I have no meters but I do have the option on my Yamer to do a "sound test" via the ole lobes.
    I have option to set crossover via the reciever....what should that be?
    I think I have it set at 80 or 100mhz.
    Real stupid question.....what is LFE? :rolleyes::o
  • thsmith
    thsmith Posts: 6,082
    Motzart wrote: »
    80hz XO is good starting point. If you can borrow a RS SPL meter make sure your mains and Sub are balanced, meaning play a test tone on AVR say at 75db then use you level settings to get sub at 75db like mains.
    Low Frequency Effect (LFE)
  • Motzart
    thsmith wrote: »
    I know nobody that has a meter to borrow.....I'll hafta to rely on my rather larger lobes. :o
    thsmith wrote: »
    I shoulda known that.....brain ****.....happens after you hit 40! :D
    Thanx that's what I ran my sub out on the AVR to on the sub with a short quality cable.
  • ViperZ
    ViperZ Posts: 2,046
    Motzart wrote: »
    Hey! Although I don't use Velodyne in my HT (NHT SubTwo here), I have had quite a bit of experience with Velodyne subs. On the budget side, I loved a pair of DPS-12 in stereo.
    I also currently use a completely restored ULD-15 in my 2-channel setup. That sub rivals my NHT in terms of low musicality and digs slightly deeper (by 1 or 2 Hz ;)).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • Motzart
    ViperZ wrote: »
    I didn't wanna get to carried away!
    With a room that's 10x15 and a small house I have enough power now.(185watts RMS)
    I see there is a HSG that's 1000watts which is suicide but I also read that they were s*** cuz the amps don't hold over a year.
    Velodyne musta dropped the ball on this series!!
    Never read such poor reports on Velodyne as I have on these.
    At $1400 I'd be royally PO'd as well!!! :mad:
  • CallingMrBenzo
    CallingMrBenzo Posts: 34
    how do you like the sub for home theater so far....im strongly considering this sub if i can get one near the price range you did...:)
    My College Setup
    TV: Mitsubishi WD60735
    Gear: Logitech Harmony Xbox Remote
    Toshiba HD-A3, Samsung BD-P1500
    Sony SCD-CE595, Direct TV HD DVR, Xbox 360
    Receiver: Onkyo TX -SR 606
    Speakers: JBL S Center, JBL S310,Polk R300 R
    Sub: Kicker L5 in ported box
    Pics --> http://www.blu-ray.com/community/gallery.php?member=CallingMrBenzo
