just got the PSW125
mauitang
mauitang Posts: 12
I just got the psw125, and my receiver is onkyo tx-sr304, i connet from LFE use rca cable to the receiver sub out, and i don't know why the sub is so soft...i already turn sub volume to max, and play iron man from my computer,i can fell it, but not alot, can anybody help me with that???
I wonder is because my receiver not good enough for this sub?
on the receiver i set all the speakers to small and the bass to subwoofer crossover is 80
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited November 2008
    I have the Onkyo TX-SR806 and my PSW125 slams!! Your receiver shouldn't make that much of a difference in this equation since it is a self powered sub?? I may be wrong in my thinking, but that is how I see it. I ran my current setup (see signature) with my old Onkyo HTIB receiver, and it worked just fine. I had mine hooked up with a Rocketfish subwoofer cable and had no problems. My old receiver wasn't much different cosmetically from the one you have, but I think it pushed out somewhere around 120 watts per channel, not sure that would make a difference though, hopefully someone with a little more knowledge can give you a better answer.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • leroyjr1
    leroyjr1 Posts: 8,785
    Check your settings on your receiver.
  • mauitang
    mauitang Posts: 12
    leroyjr1 wrote: »
    my receiver setting is all the speakers to small and the bass to subwoofer crossover is 80, and subwoofer yes.....
    thank u guys
  • djseafood
    djseafood Posts: 73
    I'm not going to pretend that I know the answer here, but am just throwing out some more questions that may lead someone else to the answer.
    1) How is your computer output being fed to the receiver? L/R RCA or optical?
    2) Are your other speakers soft also or do they play fine when the input comes from the computer?
    3) Does your sound card support 5.1 surround?
    4) Could you try to use the speaker level inputs or L/R line level inputs on the PSW125 instead of the LFE input and see if that makes a difference?
    HT
    Receiver: Onkyo TX-SR506
    FR: Polk Monitor 40
    CNTR: Polk CS2
    Sub: Polk PSW505
    RR: Infinity SS2001 w/ SpeakerCraft 5.25" aluminum woofers and 1.5" ports
    Patio: Polk Atrium 45
    TV: Sony Bravia KDL-46XBR9
    BD: Sony BDP-S570
    Gaming: PS2 and Wii
    PWR: APC C-5
    Work
    Receiver: h/k AVR 20
    CD: marantz Professional PMD320
    Mains: Infinity SS2005
    2nds: DLK 1 1/2's
    CNTR: Infinity Sterling Video
    Subs: Paradigm PS-1000 w/ beefed up power circuit resistors and custom 15" w/ Polk PSW-505 amp.
  • djseafood
    djseafood Posts: 73
    By the way, it shouldn't matter at all what kind of internal amp your receiver has. Before my Onkyo receiver came in, I hooked my PSW505 up using the L/R RCA out from my TV and the sub was very loud! No receiver needed, just an input signal. You can even run a mini-jack to L/R RCA cable from a CD player or MP3 player and you should get sound from the sub. (another member here on the forum helped me with that tip but the name escapes me right now)
    ***Kex is the one that helped me with that tip. Thanks again :) ***
    HT
    FR: Polk Monitor 40
    CNTR: Polk CS2
    Sub: Polk PSW505
    BD: Sony BDP-S570
    Gaming: PS2 and Wii
    PWR: APC C-5
    Work
    2nds: DLK 1 1/2's
  • concealer404
    concealer404 Posts: 7,440
    Is this one of those recievers that has the "double bass" function?
    I have to use that on my Onkyo...
