Running an amp rated higher than subs
vandiar2
(posted this in basic wiring.. I assume it should be posted here sorry)
I have seen some people say no and some say it is ok. I need a definite answer here. I am running two mtx 225 rms a piece.. I was wondering if it is ok to run a 600 rms amp? From what I understand technically it is ok to run an amp rated higher than the subs so long as you keep the gain down ... and some people saying to match the amp's rms with my subs. Any suggestions? Thanks in advance!
Post edited by vandiar2 on
