Another intergrated/preamp ?
Braddles
Braddles Posts: 228
edited November 2008 in 2 Channel Audio
Sorry guys i know you are prob sick of this question but i too would like to know if i can use my old Luxman LV 113 int as a pre.
It has some jacks called "signal processor" in & out, L & R.
Are these the same as pre outs? Can i hook a power amp up here?
Cheers for the help.
Amp - Jas Audio Bravo 3.2 set
Power Cord - Tunami GPX
CDP - Marantz cd6002 - Audio gd Ref 5 Dac
Speakers - Tekton Lore,Polk Audio RTA11tl completely refreshed.
Post edited by Braddles on
    mhardy6647 Posts: 35,195
    possibly, but the volume control and tone controls might not be in the loop.
    (i.e., it could be like a tape loop rather than pre in/main out)
  • Face
    Face Posts: 14,340
    Ask a few more times, maybe you'll get the answer you want. :D
    or just try it... as the Brits say, "suck it and see".
  • curved
    curved Posts: 664
    If you try it, make sure the gain on your sub is DOWN all the way.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
    I was hoping that would be self-evident :-)
  • curved
    curved Posts: 664
    You never know.......;)
    Pre - Nak CA-5
    BR - LG BD390
