Micropro owners
leroyjr1
leroyjr1 Posts: 8,785
I just purchased Polks Micropro 4000 and I needed help with setting it up. Do I run audessey on my avr then run the room optimizer or the other way around. Also when I run audessey and/or room optimizer do I set the sub to max (40)? Will I need to use my SPL meter? Also is there some kind of fan built inside the sub, sounds like a fan running when I put my ear close to the woofer? Any help will be appreciated
Post edited by leroyjr1 on
  • McLoki
    McLoki Posts: 5,231
    edited November 2008
    I would run room optimiser on the sub first.
    Set the sub to 30 and run audessey. If it adjusts your subwoofer channel on the AVR above +7, move the sub volume control higher.
    No fan that I am aware of - might be worth a toll free call to polk tech support about that one. If it was a 60 cycle hum, you would hear it plenty far away from the sub. I will put my ear near the sub tonight and let you know if I hear anything. (only a 13" box sitting on the floor - plenty far away for me to miss a fan noise - I have a micropro 2K so the amp will probably be different anyway) How far away from yours can you still hear the fan??
    Michael
  • leroyjr1
    I can hear the noise about a foot away. Might be the digital amp or something . Hopefully someone else can chime in and help out.
  • Ricardo
    Ricardo Posts: 10,634
    My micropro 3000 is absolutely silent; I'm with Michael on that one; call Polk CS.
    SOPA
  • leroyjr1
    Ricardo wrote: »
  • curved
    curved Posts: 664
    What did you buy now......lol
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • leroyjr1
    curved wrote: »
    Thanks a lot. LOL
  • mmadden28
    mmadden28 Posts: 4,283
    I just hooked up my new uPro4k, and I hear some kind of noice from the driver as well. Not sure if its the same, almost a swishing, but only when its moving heavy. I have to have a closer look at it. I don't hear anything steady.
    Hey that oval-like radiator on the bottom is pretty cool. I didn't see that in any pics yet, I'll take a pic and upload it.
    Leroy, did you get your's at Tweeter too?
    ____________________
    Pool: Atrium 60's/45's
  • leroyjr1
    It even makes a noise when the audio gear is disconnected. I got it from a fellow polkie
  • leroyjr1
    It has the same fan noise as my ps3, hd dvd and projector
    treitz3 Posts: 20,206
    What gear do you have it hooked up to?
  • leroyjr1
    Onyko 805. Just plugging it in to the outlet got the hum/fan noise.
  • Ricardo
    leroyjr1 wrote: »
    Work it out directly with the fellow polkie.
    SOPA
  • mmadden28
    leroyjr1 wrote: »
    Then that's not the same as my issue. Mine is brand new out of the box. I'll look further into my issue separately.
  • timlitton
    timlitton Posts: 289
    edited January 2009
    Did you ever get this sorted out? Also, what are your impressions of the MicroPro line? I'm thinking about picking a 1000 after I lock in an amp.
    Slowly emerging from the 90's
    Fronts: Polk LSi15's
    Center: Polk CS350ls
    Pre: Sony STRDA555ES
    Amp: Rotel RMB-1075
    Sub: Velodyne SPL-1000
    TV: 46" Sharp Aquos LCD
    Dust magnet: Sony PS3
  • mak99
    mak99 Posts: 362
    edited January 2009
    I'm also wondering what ever became of this noise. I'm tempted to upgrade my PSW505s for the microPRO 1000s...
    Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!!
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    I took a look at it for him. I could not hear any sound from the cone when hooked up to my sonosub till the gain was at full or near full with my ear right next to it. Then I listened through the port of the 5 foot "echo" chamber(kinda like listening to a sea shell)and I could hear it then. It is a 1000 watts digital/switching amp. Much more than most plate amps. Most amps are about 300 watts. There was no cone movement at all. No DC voltage, and no ac voltage. Any voltage was at to high a frequency to be picked up by an AC multi meter. The sound was coming from the from the speaker. It did this at near full gain. You should never have your sub set that high, and to hear it you need your ear right up to it, or in an "echo chamber". I spoke with him, and the seller. They had two amps for it. Both did the same identical thing. I feel there is no concern with it. It is at full gain and your ear has to be right at it to barely be able to hear it. Keep in mind that the sub I was using is a Dayton Titanic MK III with a very hard cone. I used that driver because I knew if it was going to be heard it would be heard on that hard of a driver. If you turn your receiver up all the way with speakers hooked up to it you most likely will hear the same kinda sound faintly from your speakers.
    Ben
    Ben
  • leroyjr1
    edited January 2009
    Thanks again Ben
  • ben62670
    edited January 2009
    No problem I am glad I was able to help, and it Twernt nothin with the Polk relay system:) Now you have a spare. I was asking the seller who owned the second amp. I was even thinking about how I could make an offer to to take it off your hands. It moved that 800 watt Titanic hard no problem. Never got anywhere near hot. Not even barely warm. If you ever are in the Atlanta area you owe me a six pack or Arizona Iced Tea R/X:D
    Enjoy
    Ben
    Ben
