7.1 setup
edited November 2008 in Speakers
I am in process of upgrading my HT from 5.1 to 7.1 ( 5.1 setup consists of Monitor 60 - front speakers ; Monitor 30 - surround speakers , cs2 - center : PSW125 ) .I am considering below option
1. Monitor 60 (front ) + Monitor 40 ( L-R surround) + Monitor 30 ( back surround) + CS 2 + PSW 125
2. Monitor 60 (front ) + Monitor 30 ( L-R surround) + Monitor 30 ( back surround) + CS 2 + PSW 125
3. Monitor 60 (front ) + FXiA4 ( L-R surround) + Monitor 30 ( back surround) + CS 2 + PSW 125
Room dimension : 20 ft X 12 ft
The listening area is touching the back wall ,where back surround is to be placed meaning there is hardly any distance between listening area and back surround speakers . Should I stick to 5.1 setup only?
Please advise
Post edited by sps on
Welcome!
    Me personally would stick with 5.1 if you do not have any space behind you to really give to rear surrounds. I would rather upgrade the subwoofer or even add another. Just my opinion.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
    There is no point in putting speakers behind you, in there is no "behind you". A properly set-up 5.1 system sounds amazing, and is better than a mediocre 7.1.
    I would suggest the FXi as surrounds since they will be close to the listening position. They will diffuse the sound and make it less directional than the Monitors.
    Fronts: Polk RTi10
    Center: Polk CSi A4
    Surround: Polk FXi3
    Sub: Dayton 100
    AVR: Pioneer VSX-1018AH
    Agreed, in your case stick to the 5.1 and use the cost savings for projector /screen, especially if that room is dedicated.
    Thanks for the advice. Can the rear speakers be only 1 feet behind listerning position ? In that condition , is 7.1 setup good enough. Just want to keep provision for Blue-ray and PSP3.:). I find PSW 125 is enough and could not find it lacking ..any suggestion for upgrade.
    sps wrote: »
    you need more than 1 foot behind listening position in a 7.1 setup IMO. If youre thinking of replacing sub, check out SVS, Epik.
    Thanks for suggestions . Having 4 tower speakers in one room means hard time with family. Yes as suggested , I am moving sitting space little bit to adjust rear speaker. Most probably I will be sticking to Monitor 60 + Monitor 30 + Monitor 30 + CS 2 + PSW125 ...does it make any sense to opt for Monitor 60 + Monitor 40 + Monitor 30 + CS2 + PSW 125 .
    just get a SurroundBar 360 and call it good. ;)
    PolkFest 2012, who's going>?
    sps wrote: »
    I am using Monitor 50 for fronts and monitor 40 for surrounds and monitor 30 for rears(not yet hooked up because I dont have the space behind the sitting area). The 40's are a nice size bookshelp and I like the sound that they produce as surrounds. But if you dont want a nice size speaker for your surrounds, there are not the ones for you. the 30's are a nice size and sound pretty good IMO. Hope you have fun with the monitor series. I am lol
Welcome!
Welcome!
