Fuse To Big?
bigaudiofanatic
I recieved my amp wiring kit today from kicker and it says it is for a single amp hook up. But here is the thing the fuse that it came with is a 100A fuse.:eek: I have never used one this big but I am going to be running a 500 watt amp and a 50-60 by 4 amp is this fuse still to big or can i use it.
If you want to look up here is the link. One thing to not is the pick shows a distribution block but this does not have that. http://www.amazon.com/Kicker-05PK4-4-Gauge-Single-Amplifier/dp/B000FI4TTK/ref=sr_1_8?ie=UTF8&s=electronics&qid=1227050151&sr=1-8
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
Post edited by bigaudiofanatic on
BumpHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
That fuse is not too big. Plus it will give you some room should you ever want to upgrade to bigger and/or more amps.polkaudio sound quality competitor since 2005
is 80A too small for 1100rms?2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
the fuse on a wiring kit is really to protect against short circuits. it saves your car from burning/melting when a short happens.
the fuses on the amp protect the amp. do not ever upgrade those!
if your wiring kit has a fuse larger than your amp, that's fine.
if it is smaller, see if it can be (safely) upgraded. ie - your wire *may* handle up to 100amps if it is 15 feet long. if they supplied you with a 50amp fuse, u can always upgrade that. (figures used here are imaginery, please consult the AWG wiring chart first) -
The fuse should be lower than the current capabilities of your power/ground wire to the amplifier.
The inline fuse is to protect your vehicle/system from short circuits due to defective power wires the fuse should be no more than 18" from the battery, closer is better.
http://www.bcae1.com/ -
eloplayspolo wrote: »is 80A too small for 1100rms?
Generally no.....
Could be, yes....
Will it be, doubt it......
