Wanna see a Magic Trick...?
Fatbrando
Fatbrando Posts: 275
edited November 2008 in The Clubhouse
So tomorrow I have to take the money allocated for my new SDA's and fix my automobile. Watch as all the "pristine, upgraded, mint condition, selling at incredibly low price's" SDA's come out of the woodwork here in Southern California. Get ready the deals are gonna jump out at ya! Best of luck and I hope I'm wrong. Keep on Polkin'....
FB:(
Harman Kardon HK 3490
Stanton STR8-100
Polk SDA SRS 2.3TL (Proud newbie owner!)
Post edited by Fatbrando on
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    I have to replace 3 of my tires, and Tie rods for my front right according to Firestone going to be around $500. :(
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • nadams
    nadams Posts: 5,877
    My truck needs all 4 tires and an alignment... $650
    My house needs 7 new windows... $994
    Every time I make a non-essential purchase, I feel guilty as all hell. But, you have to have a little fun or you'll die of stress.
    Ludicrous gibs!
  • audiobliss
    audiobliss Posts: 12,518
    nadams wrote: »
    How the heck can it cost that much?! What size are they? The 31" tires for my Cherokee are about $70-$80 a piece...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • bobman1235
    bobman1235 Posts: 10,822
    audiobliss wrote: »
    You buy some cheap-**** tires?
    I have decent (but certainly not expensive) tires on my Subaru that were 116 each from TireRack.
  • KrazyMofo24
    The cheapest tires for mine start at $110. That's just 17' for a Mustang GT. I'm hoping there will be some sales for Day after Thanksgiving.
    Setup:
  • audiobliss
    bobman1235 wrote: »
    I'm sure they're not the greatest, but I dont' think they're junk, either. Bridgestone 275/55r15. I believe they're Bridgestone Deuler H/T's.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    F1nut Posts: 50,734
    audiobliss wrote: »
    You should consider some Michelin's.
  • bobman1235
    Uhoh, fights about tire brands can get as dirty as auto brands.... :)
  • audiobliss
    Per Dad's allegiances, I'd have to agree Michelin makes great tires.
    However, they're a little too expensive to just paint the streets with. ;)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • nadams
    nadams Posts: 5,877
    My tires are 245/75R16's. I was looking at Hercules Tires... I believe All Country A/T's. If I'm not mistaken, they are a USA-made tire.
    My former neighbor owns a tire shop and that's all he sells. If he didn't trust them, he'd never sell them.
    Ludicrous gibs!
  • exalted512
    exalted512 Posts: 10,735
    audiobliss wrote: »
    Tires for 15" wheels are the cheapest tires you can buy. 16s are a little more expensive, and they go up from there. Thats in part why. Plus you figure in road hazard warranty, mounting and balancing, tax. I believe mine were around $550 for all 4.
    -Cody
    treitz3 Posts: 19,195
    Michelin is the cream of the crop. You can tell by the # of air holes [or rubber "fingers" that stick out] that help with the aeration of the original tire design during the mold process. The more that you have, the lower the quality and the more issues you have with the tire design and it is also indicative of the issues the manufacturer had with the build of the tire. All of those "fingers" indicate where the tire design had an initial failure that had to be punctured to release excess air. A well designed tire does not need many air outlets.
    Michelin will have the least amount.
    Hence the price. ;)
  • Lowell_M
    Lowell_M Posts: 1,660
    audiobliss wrote: »
    I took Michelins off my SUV that had 1/2 of their tread left and put Bridgestone's on because they were just plain terrible in the snow and ice. I've used Firestone and Bridgestone for years, but performance tires (Potenza REO50) and SUV all season. Not sure what is up with those Michelins (can't remember the model) but they were really scary in the snow. (couldn't steer or stop)
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • Lowell_M
    treitz3 wrote: »
    Hence the price. ;)
    What does mold design have to do with tire design performance?
    I know that Michelin makes some great tires (particularly performance tires) but for me there isn't a compelling reason to ditch my Potenzas for the extra $$'s. I might try Dunlop's for next year's track season just to see how much money I can save and still stay on the track.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Pauly
    Pauly Posts: 4,519
    id rather buy gear then change my oil or for that fact get it changed.
    Life without music would
  • audiobliss
    Oh boy. Dunlops are what were on my Jeep when we bought it. They were flat out SCARY! They could barely grip when it was dry, but you had NO traction if it was wet out at all. I'm not really exaggerating much either. It was VERY easy with those tires to touch the throttle mid-turn in the rain and accidentally initiate a slide. Stopping in the wet was bad, too.
    Now, in hindsight, I was a new driver then...so it was scary...now, I think I could have had a good bit of fun with those...:D :p
    EDIT - I had NO clue what those Dunlops were, as we got rid of them pretty quickly. However, out of curiosity, I just looked through some OLD pics of the Jeep when it was still wearing the Dunlops. In case you were interested, they were Dunlop A/T Radial Rovers.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • nadams
    nadams Posts: 5,877
    Have fun spending that gear money on a new car... or engine...
    Ludicrous gibs!
  • Lowell_M
    audiobliss wrote: »
    Heh heh... I fellow weekend racer bought some of the Dunlop Direzza's this season and said they are fairly decent at the track but not as good as the Bridgestone Potenzas. We will see what kind of deals there are over the winter.
    Of course, now I have the winter tires on which have much less dry grip, so I need to be careful to save the rubber and not leave too much on the road **** around.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Ricardo
    Ricardo Posts: 10,636
    Tires make no difference. Rubber is rubber. I've done A/B tests and......
    Ups. wrong thread.....
    SOPA
  • Face
    Face Posts: 14,340
    I will be spending some of my toy money tomorrow on a new water pump, tire rotation, oil change, and a new brake hose. Oh well.
  • Lowell_M
    Ricardo wrote: »
    :D I was waiting for that....
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • bobman1235
    Judging a tire BRAND based on an experience with a single TIRE is kind of silly. At least as far as performance goes - durability and reliability are maybe a different deal. But even minor differences within the same MODEL, let alone brand, can be night and day in a tire. My car came stock with a set of Bridgestone Potenza "performance" tires, which were great in dry weather and turned into slip-n-slides in the snow. I bought some all-weather Potenzas - same brand, even same model line, just a different "flavor" - and it's a completely different experience. I love the tires I have on there now.
  • Pauly
    Pauly Posts: 4,519
    nadams wrote: »
    waiting for it to die so i have an excuse to get a smart car stacked with polk gear bumping down crenshaw. ;):D
    Pauly
  • goingganzo
    goingganzo Posts: 2,793
    dam that makes my $250 each tire expencive.245/40/18
  • Lowell_M
    bobman1235 wrote: »
    Pretty silly to drive summer compound tires in the snow...
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • goingganzo
    i tryed the summer olny tires in the winter. but we olny get 40 in of snow a year here. but with my air ride it made my car realey hook
  • Face
    Face Posts: 14,340
    Summer tires usually harden in the cold, making traction worse.
    Snow tires are made to be softer in the winter months.
  • BrettT1
    BrettT1 Posts: 560
    I bought extended warranties for both of my vehicles. Of course that doesn't cover tires, brakes, shocks, struts, hoses, belts or oil changes:rolleyes:. I still have the original tires - Michelins on the van and pretty lame looking BFGoodrich on the stang. One of the BFG had a flat from a "sharp, tooth shaped rock". lol
  • sucks2beme
    sucks2beme Posts: 5,605
    Firestone sucks. Maybe not all their tires, but I've been burned several times.
    I avoid them when I can. I also got burned at discount tire on effin' tire stems.
    Tire stems! What should ever go wrong with tire stems? Seems they
    were using cheap Chinese ones that split open. I had one go out in less than
    a year. Then about two months later I saw the notice that I had to
    go back and have my tires checked out. I was a bit miffed.
    Yes, you buy new audio equipment, something's going to break.
    In fact, for me it normally happens about the same time I get the
    cash together, just before purchase.
  • Mike Kozak
    Mike Kozak Posts: 931
    audiobliss wrote: »
    When I had my 95 Corvette, the tires were only supposed to last 12 months or so and cost 300.00 each!! (not including mounting and balancing)
