db804 dual bandpass
beanders
I would like to build a dual bandpass using the Polk db804 speakers. Does anyone know what the chamber volumes and port dimensions would be? I have made the single bandpass before and I like the sound of two of them. So that is why I want to do a dual bandpass.
Thanks!
Thanks!
Post edited by beanders on
Are you building your own enclosure again?
If so, below is a link that you might find useful:
http://www.ajdesigner.com/fl_subwoofer/subwoofer.phpRubiCrawler LJ -
This might be a good starting point, it is a dual bandpass enclosure for two MM2084 subwoofers.
[URL=]http://www.polkaudio.com/caraudio/subbox/subbox_plan.php?id=45&mesurements=standard[/URL]RubiCrawler LJ
