Vehicle Performance Computer
Lowell_M
What are some of the brands of the little gadgets that measure g's, accelleration, 1/4 mile times etc. in a car? Also, how accurate are they?
I'm thinking one would be a fun little gadget to have but dont' know if they actually work and what brands are out there. Thanks!
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Post edited by Lowell_M on
We just tested one on a cell phone. If you have a Nokia,or any other Symbian Series 60 phone with GPS, you can use the same software.
Depending on how hard your car takes off and shifts, G-Techs aren't too bad for quarter mile times. I find they are usually fast by a tenth or two and five miles a hour. But if you have a stick or something that launches very hard, it will affect accuracy."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I've got a 2007 Infiniti G35S mn6 (306hp, rear drive, limited slip) So, it will take off pretty hard but it's not Z06 or anything. G-tech is the brand name?HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Ultra Bi-Wire Speaker Cables -
What's the software?HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
there are programs for iphone as well, Dynolicious is the most popular one, g tac is another one. Dynolicious is supposed to be accurate, I don't know about the others and I have no experience comparing them to time slips from a drag strip.
any of them would be great for seeing differences in your rides performance with different mods as they should be pretty consistent or just to have a little fun.HU: Clarion DRZ9255 4 Way Active:
HIGH: Polk SR52500 tweets. MID: SR5250 woofers. LOW: SR6500 woofers. SUB: Two Polk MM1240svc's 1010rms sealed in 1.75 cu.ft. AMPS: Arc Audio FD4150, FD2200 & FD1200.1. -
