Best XM stations for sound quality?
Serendipity
As XM Radio's sound quality varies from station to station, what are the best-sounding stations on XM?
Whenever I listen to Top 20 on 20, Flight 26, XM HitList, or any of the pop/rap channels I find the sound quality to be very poor. However, XM Classics and XM Pops sound great so I'd like to find more "quality" stations on XM.
Thanks!
Thanks!
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
The AC/DC channel is pretty decent. I think it is 52 or 53. 53 or 54 is pretty good to (for XM anyway)HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
I'll check those out. When I used to have XM set up in my dorm room (connected to Dell PC speakers), the sound quality was listenable on all the channels.
However, hooked up to my 2 channel rig the sound quality varies from very bad to acceptable to decent (depending on the channel).polkaudio RT35 Bookshelves
