How do I change my log in name?
Tony M
Tony M Posts: 11,184
edited November 2008 in The Clubhouse
I would like to change it to something other than my name. I think I tried all the user edit options catagories.. I didn't know in the begining it would show up but ..
Thanks for any help
Post edited by Tony M on
  • mmadden28
    mmadden28 Posts: 4,283
    5 1/2 years later?
    Sorry but I think the FBI has found you by now. ;)
    ____________________
    Pool: Atrium 60's/45's
  • ben62670
    ben62670 Posts: 15,969
    Contact Justin he should be able to change it for you. That is his screen name;)
    Ben
    I was hoping nobody would look at how long it's been like this :rolleyes:
  • zingo
    zingo Posts: 11,258
    Do I contact Justin through support?
  • mmadden28
    Click User CP (top left blue bar) > Send New Message.
    Or click here
    I tried like you directed but justin dosen"t receive messages but there were alot of justins on a list below with other numbers or letters added . I do thank you for trying to help me.
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    http://www.polkaudio.com/forums/private.php?do=newpm
    Add this user name to Recipient Username: -justin-
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
    I think it worked . It sent my request.I didn't put the - in front and after justin the other times. Thank you again!!!!!:D
  • mmadden28
    I thought I remembered there being something different about his username.
    My comuter is running real slow for some reason and it took awile for these letters to appear on my screen. I have to go now and thank you again. you all are great. you'll hear from me again.
  • mmadden28
    We'll need a code word to know that you are who you say you are or were since you might not be the same..:confused:..How about "expialidocious" ??
    lol.. I think "gollum" might fit this situation.
  • hockeyboy
    hockeyboy Posts: 1,428
    Make sure he changes it to Anthony Millard.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
