MiDock Portfolio Question.
cmy330go
Does anyone know for sure if it is safe to run the MiDock Portfolio off AC power while there are batteries in it? Wasn't sure if it would attempt to charge installed batteries while plugged in. I assume it doesn't but just want to make sure.
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
2 CH
Post edited by cmy330go on
It doesn't specify in the manual: http://www.polkaudio.com/downloads/manuals/home/MiDock%20Portfolio%20Manual.pdf
But, since there are no warnings against doing so, I wouldn't be too concerned."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Yea I was thinking the same thing, but just want to be certain.HT
2 CH
