XLR cable to my sub?
paymontna
paymontna Posts: 188
I am running XLR cables from my TGP processor 5 to my TG 7 amp for my 6 channels. Will I get the full balanced effect w/o a balanced cable run to my SVS pb/2 ?
And I mean calling all cars, blackhawk down, mushroom cloud, Three Mile Island, lock the door behind you kind of mad.:mad:
Post edited by paymontna on
  • zingo
    zingo Posts: 11,258
    edited November 2008
    Unless your amp was designed for balanced wiring, it won't make a difference what kind of signal you run to it. IMO, as long as it's getting a signal and you're getting sound out of it, success.
  • paymontna
    zingo wrote: »
    I was under the impression that all speakers connected through the system had to be balanced in order to lower the noise floor, but I am wondering if the sub would be excluded because its power supply is isolated. The SVS pb 12 /2 is wired to run xlr cables.
    Chris
  • Eric W
    Eric W Posts: 556
    Are you getting any problems with extra noise or humming or buzzing? Balanced connections have their place, but most home audio applications really don't need them...
    -Eric
    -Polk Audio
  • ben62670
    ben62670 Posts: 15,969
    Eric Wong wrote: »
    +1 A lot of the Balanced amps don't even use the V- signal;)
    Ben
  • paymontna
    I was getting noise and feed back from the analog cd input. I am using it for my Ipod. I was going to upgrade to silver interconnects anway, so I went with the bettercables.com silver serpent II since they were on sale. I balanced out all 6 channels not including the sub, and it killed the noise.
  • ben62670
    paymontna wrote: »
    You should have called...
    Ben
