Speaker Jumpers
rdb2001
rdb2001 Posts: 791
edited November 2008 in Speakers
So I have upgraded my system, nothing major I just have monitor series 50 for fronts, monitor 40, for surrounds and monitor 30 for rears. These are my first speakers that require jumpers. I have made some using some 12 guage rockford fosgate speaker wire that I had left over from my truck install. I used gold plated spade rings. Would I be better servered buying some jumpers elsewhere or will i not really hear a big difference from the ones I made. Thanks for the help
Post edited by rdb2001 on
  • curved
    curved Posts: 664
    IMO, that will be fine. That's exactly what I did at first.....until I ordered the Quad 14AWG from BlueJeans. Very happy with the results:D
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • rdb2001
    rdb2001 Posts: 791
    curved wrote: »
    So was there a major difference in sound quality? I have search on the online and jumpers can get quite expensive. Just want to make sure I will benefit from buying them. I like the monitors sound. I have had them only a couple days, waiting on my onkyo 706 to arrive and my boston acoutics HPS 12HO 12 inch subwoofer.
  • curved
    curved Posts: 664
    I'm not even sure I noticed any difference - placebo maybe.....I did notice a difference when I upgraded the speaker wire to the quad though.
    Pre - Nak CA-5
    BR - LG BD390
