Oh man these look like some fun speakers!
SolidSqual
Post edited by SolidSqual on
Nice lookers......bet they sound even better than they look.Oh well,maybe next year.HT SYSTEM-
lsi 9's -
Those do look fun.
Is that my eyes or are their woofers on the side? -
They weigh 341lbs each!?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Solidsqual , Get them and let us know how they sound
Since he lives in Indy....he better get an ear on some SP tech's first.HT SYSTEM-
lsi 9's -
Those do look fun.
Nice catch. I think you're right, 4 woofers per side. -
Do you see the small shadow of a hold above the top woofer? Do you think that's a port hole or a small driver?
Simply beautiful.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
The 6.5" midrange units feature cones made of hemp, the fibers of a plant perhaps more familiar to members of the counterculture as "weed." When grown under the appropriate conditions, Cannabis sativa does not secrete the psychoactive substance tetrahydrocannabinol (THC), but instead produces light but strong cellulose fibers that are traditionally used in making rope.
:D -
I count 5 and yes that looks like a portDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
It says ---
The enclosure is sealed... the back has a port for the MTM array
The sides have 6 8" PRs and 4" active 8" woofs per speaker- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
How can they weigh so much????????????????
Sheesh!"Wish I didn't know now what I didn't know then." Bob Seger -
They are made of graphite basically... lol
Man you guys need to learn to read
35large.... I would stick with Watt puppys some good electronics to run them with....Mains.............Polk LSi15 (Cherry)
I pooped my pants
Mike Kozak wrote: »I pooped my pants
Run faster next time.Mains.............Polk LSi15 (Cherry)
