lsiC wall mount
I took the advise from another thread and raised my center 10 inches from 22 to 32 and hay what a difference. The only problem my stand will have to be replaced with a wall mount. I found the bt-15 wall mount. Is anyone useing this wall mount for their center. Just wondering if the lsiC center could be mounted with this. Thanks
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
Can you put it on top of your TV? (like on a shelf or something?)Mains.............Polk LSi15 (Cherry)
No i have a flat 58 panny and i will have to put it right under it. With the wiring and all things considered it's the easiest place. Not to mention the sound difference. By the way it was your post which got me off the couch to try the adjustment. ThanksOppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
did you try the center in its original location, but tilted twords the lsteners ears? (rubber doorstops work well for this)Mains.............Polk LSi15 (Cherry)
Yes i tilted it up with pegs which came with the sanus stand. You know at 32 inches now that is right at ear level on the couch. Back to the mount do you think this would work with the lsiC. The mount is rated up to 33lbs.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
Doug,
The bt-15 should be fine if you can find studs for each bracket to mount to.
I use the same mount for my CSi3 - and the bt-15 can easily hold more weight.
Cheers,
Erik
Hey thanks Erik looks like you have the same mount and about the same hight. Thanks for sending me the photo. Looks great.
Take care DougOppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
