Velodyne F-1000 driver replacement
gwh
Any suggestions/recommendations that would closely match the original driver.
I've got a $20 bill in the unit, cabinet, amp, & grill are in good shape but the driver is quick to bottom out/pop.
Not looking to spend a lot on a replacement driver since this is not my primary sub.
Thanks in advance for your input.
G
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
Read this. The unvented servo enclosure cannot handle sustained lows from movies. You're going to have to get a new sub to replace it.:(Home Theater:
Onkyo TX-SR805
Behringer EP2500 for SDA's
Polk SDA II fronts
Polk Monitor 5Jr. surrounds
Polk Monitor 4 back surrounds
DIY A7-900 and DIY A3-300 -
:):):) HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
Testing
Testing
Testing -
What is the internal volume of the cab and your budget?
Not real sure on cab volume, need to do some research or call velodyne I guess.
Budget? Cheaper the better;)
Though maybe some of the old dogs here had been down the same or similar road.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Take the driver out, and measure the L/W/H in inches. Let us know
Ben -
Isn't F-series very similar to ULD series, except F-series is front-firing and ULD is down firing? If that's correct, then you will only be able to use the speaker from one of these subs - the speakers have a built-in acceleration/distortion sensor, without which the feedback in the amp won't function.
Regarding bottoming out in HT applications, at least in my ULD-15 there are adjustment resistors, which will let it be compliant even with current THX standard (the service manual explains which ones to change and which values to choose).Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Good point,that could be problematic depending on how they implemented the servo.Isn't F-series very similar to ULD series, except F-series is front-firing and ULD is down firing? If that's correct, then you will only be able to use the speaker from one of these subs - the speakers have a built-in acceleration/distortion sensor, without which the feedback in the amp won't function.Testing
Testing
Testing -
Okay I pulled the driver and there is more than just speaker wire running to it.
Appears this complicates the situation and narrows down replacement driver choices.
Thanks for the replies!
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Yes it will likely have another pair of thin gauge wires with a connector that attaches to the driver for the accelerometer.You could hook up an old driver of some sort just to try and see if the amp will work without this accelerometer lead connected.If it is a closed loop feedback system then it won't without the correct driver.Okay I pulled the driver and there is more than just speaker wire running to it.
Appears this complicates the situation and narrows down replacement driver choices.Testing
Testing
Testing -
It's worth a try, but I believe Velodyne said that the system may/will go into oscillation. The other thing about this series of subs, the speaker has to be completely seated and fully screwed into the enclosure. That's the only way it can be tested - otherwise, the system goes into oscillation.
Just remembered this! Velodyne's tech support checks this thread regularly on AVS forums. They are usually pretty helpful:
http://www.avsforum.com/avs-vb/showthread.php?t=304306Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Thanks Viper thats great info.It's worth a try, but I believe Velodyne said that the system may/will go into oscillation. The other thing about this series of subs, the speaker has to be completely seated and fully screwed into the enclosure. That's the only way it can be tested - otherwise, the system goes into oscillation.
http://www.avsforum.com/avs-vb/showthread.php?t=304306Testing
Testing
Testing -
Yes great info!
I dropped velodyne a line on their customer support page....maybe they can hook me up on the cheap.:)
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Yes great info!
G
In my case (for ULD), Velodyne said that they do not support this series any more. However, they do offer a great discount on a new series of subs instead.
Since I really wanted to restore my ULD-15 (and I did restore it!), I had to wait until another speaker showed up on ebay. Took me a couple of months to find a replacement.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Call KURT at Velodyne.... Actually if you email him your home phone number, he'll call you during the evening. He hates email. LMAO
I dumped my velodyne Servo F1000X, 6 months ago, while it was still in perfect condition, You all should do the same with the older servo subs. Velodyne does not have any parts for replacement or repair and never will, according to KurtELITE VSX-99 REFERENCE
ELITE PD-65
SDA-1C's with new RDO194-1 tweeters as MAINS
MAGNEPAN TYMPANI 1D's for alternate fronts for classical music
PARADIGM REFERENCE CC-450 Center
MONITOR SERIES II... M10 REARS
2 POLK DSW-600PRO SUBS
"ROCKIN THE HOUSE" -
CowboyRJB2 wrote: »I dumped my velodyne Servo F1000X, 6 months ago, while it was still in perfect condition, You all should do the same with the older servo subs. Velodyne does not have any parts for replacement or repair and never will, according to Kurt
That's a pretty bold statement to make. I love the way ULD-15 sounds. In the music application, it seriously kicks **** compared to DD series subs.
The only parts, which are irreplaceable are the speaker itself and the acceleration sensor. If the sensor is a toast, you probably won't find one. Otherwise, all the parts inside the amplifier are standard electronic components with absolutely nothing special.
Here is one of the photos after the sub got rebuilt:
B&W CDM1-SE fronts
B&W CDM-CNT center
I'm not making that statement. That's what Kurt told me on the phoneELITE VSX-99 REFERENCE
ELITE PD-65
"ROCKIN THE HOUSE"
