When is one 20 amp circuit not enough?
NewHTguy
NewHTguy Posts: 584
edited November 2008 in Electronics
Need some help from the electronics experts. Right now my entire living room is on a 20 amp circuit. I have not had any trouble running what you see in my signature plus a cable box and Samsung 52 inch LCD. Would adding a 250 wpc 2-channel amplifier require more than the 20 amp circuit can give?
MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s
Post edited by NewHTguy on
  • ben62670
    ben62670 Posts: 15,969
    Although your CB may not trip you may experience a voltage drop, and depending on what else is on that circuit you may want to add a dedicated outlet. Lights., and other things may induce noise. YMMV
    Ben
    Ben
  • brody05
    brody05 Posts: 329
    20 amps is in the vicinity of 6000 watts (or at least it is in NZ with 220v), I guess amps is amps though. Most systems wouldn't be using near that.
  • Sherardp
    Sherardp Posts: 8,038
    If its cheap to do then sure add another. I run 5 20amp breakers in my dedicated room.
  • NewHTguy
    NewHTguy Posts: 584
    Sherardp wrote: »
    I don't know how much it would cost. There would be a significant psychic cost imposed by my girlfriend who already thinks I'm crazy.:D
  • NewHTguy
    NewHTguy Posts: 584
    brody05 wrote: »
    Is the calculation, ROUGHLY,
    watts = amps x voltage
    I assume there is more to it than that, but is that a good approximation?
  • NewHTguy
    NewHTguy Posts: 584
    ben62670 wrote: »
    Ben
    Thanks Ben. Right now a couple of CFL lamps are all I have.
  • ben62670
    You are fine. That money could be used better elsewhere. Tell your GF that you decided to get this(whatever it may be) instead of a dedicated outlet:)
    Ben
    Ben
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Wait doesn't CFL introduce noise on the line? Wouldn't anyone above you average AVR / Speaker setup be benefited with a dedicated outlet or two?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • brody05
    brody05 Posts: 329
    some real power hungry amps would certainly benefit from its own line, I have one for the Verastarr.
    But most houses run more than a few power points off the same breaker, throw a switch at the power board off and see how many plugs go down.
    We have an induction hob that needed a 30 amp one, talk about power hungry, it uses more than the stereo at 7200 watts :eek:
    Not sure about the conversion formula, just remember that number from when the hob was wired up a couple of months ago.
  • NewHTguy
    NewHTguy Posts: 584
    Lasareath wrote: »
    When I power my whole system at full blast it draws around 5amps
    That's all? Do you have a powered sub and amp?
  • disneyjoe7
    Sal,
    My thinking is that display is average not peaks where if you're pushing like that I'm sure you can draw something like 16amps or so like my self.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    treitz3 Posts: 19,999
    To answer the question above, when the lights dim considerably when lettin' loose or the circuit breaker pops more than once a month. If you are running more than 20 amps on that circuit.
    Another circuit wouldn't hurt and might help the overall performance of your system depending on what you have running but IME, it isn't necessary unless the above conditions happen.
    VR3 Posts: 29,435
    Ive ran 5 amps, a tv, cdp, dvdp, consoles, preamps, receivers, powered subs, computers on one circuit with zero problems...
    Trey, you forgot the fans......
  • mmadden28
    mmadden28 Posts: 4,283
    I've had my whole HT system (see my sig) on a single 15A breaker. Max current draw when running full force? 11.4 amps (IIRC). Never tripped, but the lights dimmed whenever the amp turned on. My entire Family room was also on that same circuit, including the ceiling fan, and all the lights. The voltage reading at the HT would always fluctuate. :(
    My HT is about 100' from the main panel and I was getting 111.8VAC at the power conditioner when the voltage at the panel was 121.8VAC. Of course that is sort of expected when pulling 11+ amps across 100' of cable. Huge Voltage drop. I couldn't help but wonder if I was starving my setup of some full flow juice...:confused:
    I've since upgraded by adding two additional 20A circuits with 10awg Romex (10awg to help further reduce the resistance/Vdrop for the long distance). One circuit for my amp, and one for the rest. My lights don't dim anymore and I now have a steady Voltage reading at the HT setup (and with minimal if any VDrop). That's gotta be doing something good for the system. :cool: Yeah I may have gone over kill and spent more than I needed to on cable. I could have just installed a single additional 15 or 20A circuit, but I do stuff like that ...:o I wanted to give my amp its own, I wanted to give the rest of the HT its own, and not chance any noise induced onto the circuit from my lights, CFLs, or my ceiling fan.
    You really don't want to run your circuit close to max-it needs breathing room, esp for dynamic demands from your amps. Its possible my setup was pulling more than 11.4A max, but my meter wasn't fast enough to catch it if it were.
    I would try the setup with the new amp added on your existing circuit and see how it goes. See if your lights dim. If you're able, measure the voltage at the panel and at the HT. Measure the current demands of your setup. Take it from there.
    ____________________
    Pool: Atrium 60's/45's
  • disneyjoe7
    Sal, I'm going by an KillAWatt meter, not your typical audio filter, can you place one of these at the wall and compare but I sure one is an average where one is more peak value. But all in all Lights dimming is the best test, sorry to say have a lot of that, at Christmas with tree lights the bass note dimming light thing is kind of funny. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • mmadden28
    With my Kill-a-Watt, I found that my prelit Christmas tree was drinking 400 frickin watts! :eek:
    I don't leave that thing on all night long anymore.
    FYI, for my measurements-I used my Belkin PF60's meter, my Kill-a-Watt and a Fluke Clamp-on VOM at the panel and at the outlet.
  • disneyjoe7
    Well my Kill a Watt, I found that my listening to my xm radio in the morning was 250 watts a hour. :eek:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ben62670
    I had 3 GFA-565 Mono blocks on one circuit, and we were cranking to the tune of 123db peaks. The PFGA boys were there, and lightman was looking on. The voltage never dropped. This was right out of the wall socket. The wire run to the panel was only 25 feet in the wall. Like mmadden if the voltage is not dropping, and you have no noise you are doing pretty good.
    Ben
  • NewHTguy
    NewHTguy Posts: 584
    Many thanks for all of the good feedback. At the very least it sounds as if I should give it a try as is. Thanks again. Good stuff.
  • hypertone
    hypertone Posts: 150
    20 amps on a 120v circuit is 2400 watts.
