Budget Diy Metal Mini Monitor
Systems
I came across this design on Zaph audio's site and thought they would be a perfect choice to handle the surround duties in my HT.The drivers are relatively inexpensive but they offer excellent performance for the money.
The tweeter is Vifa 1"aluminium dome($15) and the woofer is a 5.25 " aluminum coned unit from MCM($18).
Ofcourse even the best drivers in the world will only sound as good as the crossover that blends them together.For this pairing Zaph has used his considerable design skills and developed a 24 db Linkwitz Riley xover at 2k.
Parts quality is in line with the price level of the drivers.(No $40 Sonic Caps for the $15 tweeter).Instead in the tweeter circuit there is a Bennic polyprop and 2 Eagle resistors and a Solen air core coil.
The woofer circuit has a 12uf mylar cap,1 eagle resistor,.4mh air core coil; and a 2.7mh steel laminate coil.While I would prefer using an air core in place of the steel laminate, a 10 awg would be required to get the correct DCR value and would cost an incredible $88 each vs $15 for the SL.
Testing
Testing
Testing
Testing
Testing
Nice box. How are you going to finish it? I think that 5.25 needs a bigger magnet:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
1) That box seems big. What is that, like 0.3 ft^3 on a 5"? Just how low does this 'monitor' play?
2) Define budget! What's the total damage?
3) Damn you do some nice woodworking. I can see you probably feed the tablesaw by hand(unguided), but the recesses are flawless. -
Thanks Ben.I will veneer the sides , top and bottom and paint the front and back panels with a textured black.I plan to build some matching 24" stands as well.Nice box. How are you going to finish it?
Good guess;) just over .3 ft^3.Even though the magnet on the woofer is larg-ish for 5 incher (as Ben pointed out)it's actual Qts is on the hi side at around .5 thus requiring a bigger box.1) That box seems big. What is that, like 0.3 ft^3 on a 5"?
Low 50's.Just how low does this 'monitor' play?
Without counting the MDF and cost of shipping parts from the US of A it's approx $150.Define budget! What's the total damage?
ThanksDamn you do some nice woodworking.
Your good,how can you tell that from the pic's?I can see you probably feed the tablesaw by hand(unguided), but the recesses are flawless.
Actually I used the fence as a guide and a stacking DADO blade.It does a nice job on MDF. Testing
Testing
Testing -
Oh forgot to mention it will be ported.(had'nt yet cut the port opening when pic's were taken).That is how it can dig into the low 50's.Just how low does this 'monitor' play?Testing
Testing
Testing -
In the pic with all sides mounted except one, you can see the bracing piece of wood has the telltale arcing saw mark of a piece of wood that jittered. I spend a good amount of time sanding these bad boys, as my table saw is small for the pieces I'm cutting.
I haven't looked at the effeciency of that woofer, but I get the feeling it's <90dB/W/m. I hope she has a smooth response. -
That is amazing woodworking GV. There is nothing like good craftsmanship on a speaker cab to set it apart.
Yeah, you definitely have the attitude of building it right the first time.
Good eye.;)In the pic with all sides mounted except one, you can see the bracing piece of wood has the telltale arcing saw mark of a piece of wood that jittered.
It only 86db-ish ,the final system response is somewhat lower .I haven't looked at the effeciency of that woofer, but I get the feeling it's <90dB/W/m.
Yes very smooth through the mid band until 10k were a break up mode shows it's ugly head.But the xover is low enough that the peak isn't a problem.I hope she has a smooth response.
Here is the data sheet for it. http://www.mcmelectronics.com/content/ProductData/Spec%20Sheets/55-3870.pdf
And here is the details on the design. http://www.zaphaudio.com/ZMV5.html
Thanks Zingo.Having the right tools is a big help.That is amazing woodworking GV. There is nothing like good craftsmanship on a speaker cab to set it apart.Testing
Testing
Testing -
While I'm on the GV constructive criticism trip, your hole saw that you used for the tweeter is either dull, or your drill press is leaning to the side(is that possible?).
Do you build on weekdays? First impressions of the final product?
One last real question. What is the attenuation on the tweeter? Those resistor values seem low for a tweeter L-pad.
edit: did you drill the tweeter hole from one side only? Even for MDF, I drill from the front about halfway through the wood, flip it over, and finish from the back using the same pilot hole. I've built mnay arcade joysticks and the button holes come out to about an inch. Since you need to use a big old plastic nut on the inside to hold the button down, I got into the habit of always drilling clean holes. -
Very nice, where do we place an order?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
What ya mean I don't see any burn marks.:D Yep it was dull ,I should have bought a new one before using it on this project.Its trash now.While I'm on the GV constructive criticism trip, your hole saw that you used for the tweeter is either dull
Usually just weekends. They are still at the stage shown in the pics so an audition is likely weeks away.Do you build on weekdays? First impressions of the final product?
The 5 ohm series resistor is knocking off about 4-5 db.The 2 ohm shunt res is a lot smaller than normal but as the designer mentions the lower resistance helps to damp a peak at the bottom of the tweeters response.One last real question. What is the attenuation on the tweeter?Those resistor values seem low for a tweeter L-pad.
Yes,I did it straight through from the front.I didn't care if it looked a bit rough on the inside as it won't be seen.did you drill the tweeter hole from one side only?
ThanksVery nice
Madisound will sell you the parts and Home Depot the wood.:Dwhere do we place an order?Testing
Testing
Testing -
Nuts!
I have the xovers done,not the neatest but it's functional.I used some peg board for the low pass,and just glued the hi pass to the terminal plate.Testing
Testing
Testing -
Its been over 4 months but I have glued up the boxes,painted the front and rear baffles,installed the crossovers,terminal cups,damping material and bass reflex ports.Aswell in an effort to extract the maximum performance from the little woofers I wired them with MonsterCable.:D:eek:
Now I just need to slap some veneer on them and finish the matching stands.I hope to be done by Christmas.Testing
Testing
Testing -
That first pic(post 15) makes me jealous. All in all just a nice build. Your patience shows in the details.
My broken olecranon(the elbow part of the ulna) is teaching me all about patience. -
Looks good bud!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks. Part of the delay was because I scrapped the baffles shown in the first group of pics and re did them as the drivers did'nt sit perfectly flush.I dread doing the driver recess's so it took some time to build up the courage to do it. I'm cutting the veneer tonight.:)
Take care of that broken wing Shin.Testing
Testing
Testing -
Very nice job GV! It's nice to have a few dedicated DIY guys at Club Polk. Ben, Nick, Fred and some others do a nice job. Thanks for sharing your work!
Congrats!Carl -
So how do they sound!? Have you tried the correct rabbit bit for the recesses?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I won't be listening until Im completely finished the veneering.
On the first set I used a 1/4" spiral bit,and on the second a 1/2" straight bit.
I didn't test my depth properly the first time.:mad:
Aswell I need a Jasper jig.;)Testing
Testing
Testing -
Yes you do. The Jasper jig is worth its weight in gold. I do use a rabbit bit when I can to do the recess for drivers:)
Ben -
GV, Very Nice Job! Wish I could do woodworking as good as you and Ben.
Ben, I have router buddy and haven't used it yet. Is jasper jig easier to use than Router Buddy?
GV, What's your impression on your monitor build? I read about Zach's Design a few months back and always thought of building one but slacking off in many forums hasn't produced any real work so far.
I probably should spend less time chasing after my tube preamp dreams and start doing something useful.
Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
I have not checked into the router buddy much. From what I see it will work fine, just make sure the screw that keeps the circumference in order doesn't loosen up:)
Ben -
Thank youGV, Very Nice Job!
I assume you mean my impressions of how they sound.I hope to have them done this weekend so I can have a listen.GV, What's your impression on your monitor build?Testing
Testing
Testing -
Thank you
Dude I am going to report you. PF is a bad place. Stay away!
Ben -
A pair of Canadian pride GV#27
I hope your listen is worth your patience, skills and perseverance! Soon to enjoy the pay offs! DARE TO SOAR:
Wow. I love the pictures of the progress. It helps me understand what work and planning is required to build proper speakers. Thanks for sharing! And damn good work on these too!SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
