very little bass from lsi15?
slone
slone Posts: 6
edited November 2008 in Speakers
I ordered a XPA-3 to run my lsi15's and center with. after hooking up the amp I'm still getting very litte response out of the 8" subs. at 4ohms I should be putting 300wpc to the speakers, shouldnt theses 8's be pounding?
60" pioneer elite plasma, pioneer elite vsx-01, pioneer elite bdp-05fd, 2-JL audio fathom F112's, 2-Polk audio LSi 15's, Polk LSi center, Polk incieling surround and rears.
Post edited by slone on
  • tcrossma
    tcrossma Posts: 1,301
    I've run my 15's with 3 different amps at this point, and bass is the one area where I think the 15's are kind of lacking. It's nice clean output, but it's just not particularly strong bass. But they are wonderful speakers overall.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Face
    Face Posts: 14,340
    The LSi15 is pretty balanced and should have more than "very little" bass. It is probably more of a placement issue than anything else.
    Try swapping the left and right towers and also try different placement around the room if possible.
  • curved
    curved Posts: 664
    Definetely a placement issue. Play around with them a bit. I would also take some pics - you'll get a lot more help when people can see room dimensions, characteristics, etc
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • slone
    slone Posts: 6
    The problem is my avr wont allow me to run my subs and send a bass signal to my fronts at the same time.:( if I redirect the signal to my fronts I lose my subs.
    Is this common? How can I get around this? Different avr?
    F1nut Posts: 51,687
    Set the front signal to full.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I never like what an AVR does to 2 channel sound outside of Pure or Direct on some models I've played with. Stereo modes suck YMMV :)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • danger boy
    danger boy Posts: 15,722
    yeah you should set your fronts to full or large.. and that should increase the bass from them. or do the LSI15's have a volume knob on the rear of them? turn it up if they do.
    PolkFest 2012, who's going>?
  • curved
    curved Posts: 664
    My AVR lets me have 3 options:
    -BASS OUT FRONT
    -BASS OUT SUB
    -BASS OUT BOTH
    I obviously have mine set to BASS OUT BOTH.
    Pre - Nak CA-5
    BR - LG BD390
  • askinquestions
    askinquestions Posts: 80
    I believe on my 25's, I had it set at just sub, unless your using a seperate bass. You won't get the crazy bass out of say a svs, but if you monkey with the volume/Freq. you should get something pleasing. If your still having a prob., just give polk a call and they'll be happy to give you a hand. I had to do this when I first started and had a good conversation with set-up.
