Polk help matching center channel
iamthehunter
bought an RM10, 5-pack (4-RM-101's & 1-RM-202) for use with pioneer elite in bedroom HT setup; currently using only the LF/RF/CC and want to now add (2) LR/RR inwall speakers. they will be mounted about 1-ft from corner at slightly above door height, with bed below. sub is PSW303
1) need advice on inwall selecton to couple with the RM101/RM102 for 5.1 system
2) i have (2) RM101's that are not being used, but will be buying an AVR for small family room to couple with a 40" LCD. i need a cc speaker to use with these and wondered if the RM7, or RM8 cc speaker would be a good timbre match? this will be a 3.1 system until i have time after the holidays to install some more walls for LR/RR.
appreciate any help you could provide:)
Post edited by iamthehunter on
bump?
The RCi series will be the best matchup for inwall. The RM7 or 8 are great choices to match up for a center in your system. Occasionally, you can still find single RM101/102 on the 'bay, even new (open) box which would be the easy match.
I'm running an RM95 5-pack, and LOVE it for home theater. Welcome to the boards, and thanks for choosing Polk!
Cheers,
RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
