Cleaning Interior
eloplayspolo
what do u guys use to clean your interior?
My car is still pretty new but because im young and have a lot of inconsiderate friends
! i track a lot of dirt in my car (im always the damn driver and never get offered gas money grrr) so anyways. i dont want to use anything to harsh.... but i would like to restore it to look new so i can scotch guard it.
talking about the carpet.
What chemicals and tools do u guys recommend?
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Mosconi 6to8 v8
Post edited by eloplayspolo on
Standard rental carpet cleaner from the grocery store(make sure it has an upholstery cleaner hose)
like that rug doctor crap?2013 Toyota Prius
Mosconi 6to8 v8 -
Turtle Wax makes a foaming spot cleaner that's great for isolated carpet/upholstery stains.
http://www.turtlewax.com/main.taf?p=2,1,4,16
My Jeep is ten years old and I've tried to take good care of it, but sometimes spills happen (usually passengers :mad:). I was amazed at what this stuff removed from my carpet, and I used it on a work vehicle with ink on the seat- did a good job on that too.
A commercial shampooer does a great job if you have to do the entire interior, but as I found out with a near-new Olds a few years back, test the cleaning solution somewhere where it won't show...turned dark blue carpet grayish in a few spots- the GM carpet wasn't as colorfast as others I'd done. -
good ol' fashioned spit shine
works every time
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
audiobliss wrote: »good ol' fashioned spit shine
works every time
thought i posted askign for how to clean your car carpets... not your girlfriends body parts
2013 Toyota Prius
Mosconi 6to8 v8 -
Yup, Rug Doctor Crap.
It's pretty much just to lay down the soap, you will probably have to brush it with a medium bristle brush by hand then use the R.D. to suck up the soapy mess.
Or if you have a shop vac you can do the same thing.
Buy some carpet cleaning agent, scrub, then vaccum it up.
Now if you want to get crazy you can rent a steamer vac with hose attachment and really clean it up. -
i just dont want to dmg he the carpet... i want it to look new when im done.2013 Toyota Prius
Mosconi 6to8 v8 -
eloplayspolo wrote: »i just dont want to dmg he the carpet... i want it to look new when im done.
Best way to test it is to remove a seat and test where the seat will cover it. -
Blue coral on the carpet "use to clean cars" and for the dash and all Meguiars NXT tech protect. does not get gressy like armorall and lasts longer to.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
For my dash, I use a water damped rag followed by a dry rag, I use no chemicals.
Before I do any vaccuming I use an air compressor to blow out the interior which will remove most loose dust and debris, then follow up with a thorough vaccuming, every vinyl plastic interior panel gets wiped with the water damped rag followed by the dry one.
I have found this to work best, no matter what interior chemical you use there seems to be a static charge or similar "cling" effect that seems to attract dust particles. On my exterior I do use Meguiars Gold Class, it's inexpensive and pretty good. I also use Meguiars for my tires... -
i ussually use "Mothers" products, becouse there is a store near my house, but the best one Ive used is the 3M for interiors
http://www.shop3m.com/shop-by-market-car-care.htmlZ
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
KnuKonceptz MKS Kable -
i use blue coral. i find if you get the spot early enough, it will do work on it. also check out WeatherTech floor mats. They're the best floormats money can buy. Seriously.At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:( -
I use the generic WalMart weathertech type floor mats...$20pr
They keep alot of crap from hitting the carpet, I do construction so my boots are always bringing dirt and pebbles into my truck. -
his car is too nice for cheap, generic, off the wall floor mats. i'm certain he'd want to REALLY protect his investment.At Home:
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
hahaha i just have stock floor mats im a water polo player so i usualy have a towel in my car and throw it on the floor before they get in...... just sometimes they are really annoying and move the towel as they are sitting and grrr......2013 Toyota Prius
Mosconi 6to8 v8 -
ilikesound wrote: »i use blue coral. i find if you get the spot early enough, it will do work on it. also check out WeatherTech floor mats. They're the best floormats money can buy. Seriously.
I second the weathertech mats they are great.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
i think im just going to start punching people that get my car dirty.... i dont care what u say, violence solves plenty of problems.2013 Toyota Prius
Mosconi 6to8 v8
