Removing the LSi 15 woofer grill covers
Can the mesh covers for the 8" woofers on the sides of the LSi15's be removed? I just wanted to visibly inspect the driver and it didn't appear that they are easily removable, and I was afraid to break out the tools and risk damaging the wood panels.
Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH
Post edited by tcrossma on
Anyone know if they are removable?
Thanks.Speakers: Polk LSi15
Phono Pre:PS Audio GCPH -
They can. Take your time. I have watched the owner of a pair do them. Use a couple of prying tools to work them loose.
Ben -
Thanks Ben, will do.Speakers: Polk LSi15
I used my nails to remove them....it comes off pretty easy and you can put them backVideo: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
Do NOT pry them off from the bottom or top edges... you can easily chip the veneer finish. Pry them off from the left or right sides.... I learned the hard way.
