Rotel RCD 855 remote
george daniel
Before I re-invent the wheel,, anybody got one laying around,,or a cost effective alternative? Thanks in advance.
Post edited by george daniel on
I have been told that a Philips universal or Marantz remote has the same signal as Rotel. I was considering purchasing an older Rotel without a remote a while back and that was the info I was given. Don't know if it is correct since I never bought the Rotel CDP."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
I took your advice and grabbed my Ah! Njoe remote,,,and BAM,, it works perfectly with the 855,, thank you sir.Case closed.JC approves....he told me so. (F-1 nut)
george daniel wrote: »I took your advice and grabbed my Ah! Njoe remote,,,and BAM,, it works perfectly with the 855,, thank you sir.Case closed.
That makes sense because the AH! Njoe Tjoeb is a modded Marantz with a stock Marantz remote. Glad I could help."Just because youre offended doesnt mean youre right." - Ricky Gervais
george daniel wrote: »Before I re-invent the wheel,, anybody got one laying around,,or a cost effective alternative? Thanks in advance.
I was going to offer a brand new Rotel RR-D95 cheap which I bought in error and couldn't return. There are several which could help you. Glad you found an answer!
