DSW Micro Pro 3000 line in / out question
Dutch
I've checked the manual, but I can't seem to find this info.
The DSW Micro Pro has line level inputs and outputs.
I assume that this is a full range input, then the crossover dial on the back of the subwoofer lets you adjust the low frequecy cutoff. Correct?
So, are the line level outputs also full range? Or do they pass the signal after it has passed through the crossover, so only low frequencies get sent through the line level outputs?
Post edited by Dutch on
Correct. Not sure I understand what you mean by low freq cutoff...so let me say it this way; the crossover dial will input to the sub only the frequencies below the selected with the dial
Yes._________________________________________________
SOPAThank God for different opinions. Imagine the world if we all wanted the same woman
