New pair of speakers for the living room on the way
TikiToonz
* 2-Way Design
* Weatherproof Against All Weather Conditions
* 160 Watts Power Handling Each
* 10 Watts Minimum Required Power
* Silicone Sealed Glass-Reinforced Resin Enclosure
* Woofer: 6.5 Inch Black Polypropylene Driver with Rubber Surround
* Tweeter: 1 Inch Polycarbonate Dome Tweeter With Protection Circuit
* Frequency Response: 50Hz - 20 KHz
* Efficiency / Sensitivity: 89dB @ 1 watt 1 meter
* Impedance: 8 Ohm
* Dimensions: 8 1/8W X 16 3/8 H X6 1/8 D
* Wired With 19 Feet of Speaker Wire
* Designed and Engineered in USA
* Suggested Retail: $299.99
* 90 Day Warranty
Picked them up for $87 off TheDeepDiscount.com, through Amazon. I needed a pair of speakers for the living room and these things will be right at home with our tropical theme. They shipped today.
* 2-Way Design
* Impedance: 8 Ohm
* 90 Day Warranty
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
Cool. Let's hope they sound better than they look.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Those are incredibly ugly. Ron, I can't believe you didn't buy two pair.
I hope you have a shotgun handy in case they try to attack you.
