Adcom gfp565
4406bbl
4406bbl Posts: 194
edited October 2008 in Electronics
Does anybody own one of these? I have a chance to buy one and am borrowing it and I have a question,when I set the listening selector to phono,tone controls off and turn the volume up halfway,running through the bypass or lab outputs,no turntable hooked up there is a hissing sound,is this normal or is something wrong? Should the inputs be shorted to test this,or are they noisy till a turntable is hooked up? It is dead silent in any other mode. Thanks.
Post edited by 4406bbl on
  • Systems
    Systems Posts: 14,872
    edited October 2008
    Normal,the phono section has substantially more gain thus more noise will be apparent in comparison to the line level inputs.
    Testing
    Testing
    Testing
  • stubby
    stubby Posts: 723
    edited October 2008
    I agree with GV. AND, I tried it on my CT-17 Carver pre and it did the same thing as your 565; MUCH more hiss on phono. The 565 is supposed to have one of the quietest phono sections out there. Haven't heard one myself, but they are supposed to be an excellent pre with great dynamics.
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • 4406bbl
    4406bbl Posts: 194
    edited October 2008
    Ok thanks guys,the only other preamp I have with a phono input is an old 70s Infinity fet,and it makes about half as much noise but the gain might be less. I will assume the 565 is ok as it is quieter otherwise.
