narrowed down my amp choices........
IrishChamp
Just thought I would get some input, I've narrowed my amp choices down to two options for my SR6500's and single SR124DVC.
1. Audison LRx 5.1: Run Bi-amped 50x2 for tweeters, 160x2 for mid range and 1150x1 for the sub.
2. Arc SE 4200 and Arc KAR 900.1D: Run Bi-amped 110x2 for tweeters, 110x2 for mids and 750x1 for Sub
It seems to me that option one would provide better quality sound for the subwoofer and option two would provide superior quality sound from mids and highs, this is based on the opinions I've read about these 3 amps but I'd love to hear opinions from other SR component and sub owners on how these amps would match up with my speaker choices.
Now, also of importance is the price, option one would be a slightly less expensive and less complicated installation, option two would require more space, wire, etc.
thanks in advance!
thanks in advance!
HU: Clarion DRZ9255 4 Way Active:
HIGH: Polk SR52500 tweets. MID: SR5250 woofers. LOW: SR6500 woofers. SUB: Two Polk MM1240svc's 1010rms sealed in 1.75 cu.ft. AMPS: Arc Audio FD4150, FD2200 & FD1200.1.
Post edited by IrishChamp on
Id go with option 2. That gives plenty of power to each driver.polkaudio sound quality competitor since 2005
so are you saying that the tweeters need more than 50 watts, because option 1 provides more power to the midrange drivers and the subwoofer.
thanksId go with option 2. That gives plenty of power to each driver.HU: Clarion DRZ9255 4 Way Active:
HIGH: Polk SR52500 tweets. MID: SR5250 woofers. LOW: SR6500 woofers. SUB: Two Polk MM1240svc's 1010rms sealed in 1.75 cu.ft. AMPS: Arc Audio FD4150, FD2200 & FD1200.1. -
Ive found its just easier to tune them if the mids and tweets are getting the same power. The difference between 110 watts and 160 is only .5 db so youre not gaining a whole lot.polkaudio sound quality competitor since 2005
ah, I see, thanks! so If I only had 50 to the tweeters would they not produce enough sound or just cause difficulties tuning?Ive found its just easier to tune them if the mids and tweets are getting the same power. The difference between 110 watts and 160 is only .5 db so youre not gaining a whole lot.HU: Clarion DRZ9255 4 Way Active:
50 watts will work. Either of those amps will work. Its just a little easier to tune when the mids and tweets start off at the same level. And one amp is double the power over the other for tweeters while only half the power extra for mids.
Bottom line - flip a coin. Both amps will work.polkaudio sound quality competitor since 2005
ok, after all the fuss I went and bought a POLK AUDIO PA500.4, I was not getting anywhere on the other amps, things were just taking too long. Plus with the live.com disocunt I got a GREAT deal!
SO.
now another question. I need to start acumulating some good quality and affordable sound deadening and a dual amp kit. my battery is about 1ft from where I will be installing my amp so I thought I might want to just buy the necessary pieces for the amp kit and a few feet of wire by the ft. However, I don't really know exactly what pieces I need or where to get them.
I also need a source to buy the stuff to make a fiberglass sub box.HU: Clarion DRZ9255 4 Way Active:
http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-22D (if ur going to run 2 amps)
http://www.knukonceptz.com/productDetail.cfm?prodID=FH-20
http://www.knukonceptz.com/productDetail.cfm?prodID=SSRT0 (couple sets of these)
http://www.knukonceptz.com/productDetail.cfm?prodID=KLMX0BL (Power Wire)
http://www.knukonceptz.com/productDetail.cfm?prodID=KLMX0PRL (Ground Wire)
http://www.knukonceptz.com/productDetail.cfm?prodID=KLMX4BL (Power for dist block to amp)
http://www.knukonceptz.com/productMaster.cfm?category=Krystal%20RCA%20Kables (RCAs)
http://www.knukonceptz.com/productDetail.cfm?prodID=KAR08SS (Speaker Cable)
Hope this helps or gives u an idea2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
your also prob going to want some zip ties and a few other things to keep your install neat. Those power wires are a **** to strip make sure u have a good sharp tool to cut them.... i ended up using a steak knife
A lot of people recomend other stuff to deaden with because its cheaper.... but to me if u can find it for this cheap..... might as well get the best.
http://cgi.ebay.com/DYNAMAT-XTREME-BULK-PACK-10455-36-SQ-FT-EXTREME-36FT_W0QQitemZ290269740000QQcmdZViewItem?hash=item290269740000&_trkparms=72%3A1240|39%3A1|66%3A1|65%3A12|240%3A1318&_trksid=p3286.c0.m14
you will find that guy selling those all the time.2013 Toyota Prius
Mosconi 6to8 v8 -
wow, that really helps, links and everything!
Thanks!HU: Clarion DRZ9255 4 Way Active:
IrishChamp wrote: »ok, after all the fuss I went and bought a POLK AUDIO PA500.4
Good choice. Thats the same amp Im using to bi-amp my SR6500's and its working pretty damn well for me.polkaudio sound quality competitor since 2005
Yea I saw that!
plus I figured I got some beautiful polk speakers, a pulk amp should be a good fit!
Are you bi-amping them or running active?
also, are you using an EQ, I think I read some where that you ran them for a long time without an eq but recently started using one?
I'm keeping my stock head unit and a pac audio add an amp. I was going to get a RF 3sixty.2 or a JL audio Cleansweep but have read that they both have problems. I'm kind of worried I will not be able to get their full potential out of them without an eq.Good choice. Thats the same amp Im using to bi-amp my SR6500's and its working pretty damn well for me.HU: Clarion DRZ9255 4 Way Active:
EDIT: I see from your previous post your running Bi'amped, not active.IrishChamp wrote: »Yea I saw that!
I'm keeping my stock head unit and a pac audio add an amp. I was going to get a RF 3sixty.2 or a JL audio Cleansweep but have read that they both have problems. I'm kind of worried I will not be able to get their full potential out of them without an eq.HU: Clarion DRZ9255 4 Way Active:
Yeah, Im using an Alpine H700 processor/EQ. Before I got that I was using the 5 band parametric EQ off my Alpine 9855 head unit.polkaudio sound quality competitor since 2005
Yea, I hope I'm not dissapointed not having any eq, I guess I will eventually pick one up.Yeah, Im using an Alpine H700 processor/EQ. Before I got that I was using the 5 band parametric EQ off my Alpine 9855 head unit.HU: Clarion DRZ9255 4 Way Active:
what kind of car are u putting this all in again?2013 Toyota Prius
Mosconi 6to8 v8 -
chrysler 300c srt8.eloplayspolo wrote: »what kind of car are u putting this all in again?HU: Clarion DRZ9255 4 Way Active:
if anyone could look at my wiring diagram and see if I'm missing anything I would greatly appreciate it!
Are you using a 2nd battery or upgrading your alternator. You have a nice size sub amp as well as front stage amp. I think you might need some extra juice to keep both running at optimum voltage. Just a suggestion.
I'm not sure yet, I have a 160 amp alternator stock. I figured if I get flickering lights in my car I would first upgrade all my cars battery and alternator wiring, I think its referred to as "The Big 3"? then if needed I will upgrade the battery. what do you think?Are you using a 2nd battery or upgrading your alternator. You have a nice size sub amp as well as front stage amp. I think you might need some extra juice to keep both running at optimum voltage. Just a suggestion.HU: Clarion DRZ9255 4 Way Active:
Most enthusiast would say upgrade alternator first then the rest. If your alternator cant keep up with the load then you are doomed anyways. My truck has a 160 amp alternator and I am using 2 kinectic batteries in the back and a yellowtop up front. I havent had any problems so far and I get my alternater tested regularly. I would say at the first sign of dimming that would be something I would do. Just my opinion. Your voltage mean alot, your amps are most time rated at 14.4v and drop off in power if getting less than that so thats something i would make sure your amps are getting.
quick question, does the speaker wire you linked provide positive and negative wires wound together in each piece or do I need a piece for each?
If it has both wrapped together I need 60 ft, if not I need 120! OUCH, 60 is bad enough!eloplayspolo wrote: »http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-22D (if ur going to run 2 amps)
Hope this helps or gives u an ideaHU: Clarion DRZ9255 4 Way Active:
Hm, hopefully I don't have to replace it any time soon, I've not heard much about people having to replace them in this model car so I am hopeful. I do have some extra electronics already, electric auxiliary oil pump for a turbo system, methanol injection kit, and a few gauges. I do know that my car stock can have rear seat dvd, 368 watt amp, 400 watt mopar/kicker upgrade sub amp (100 to 200 from the factory).
we shall see!
thanks again
EDIT: my car shows 13.6 to 14.1 volts on the dash while running. 12.4 to 12.6 while turned off.Most enthusiast would say upgrade alternator first then the rest. If your alternator cant keep up with the load then you are doomed anyways. My truck has a 160 amp alternator and I am using 2 kinectic batteries in the back and a yellowtop up front. I havent had any problems so far and I get my alternater tested regularly. I would say at the first sign of dimming that would be something I would do. Just my opinion. Your voltage mean alot, your amps are most time rated at 14.4v and drop off in power if getting less than that so thats something i would make sure your amps are getting.HU: Clarion DRZ9255 4 Way Active:
another thing.
Do you think one 4 channel RCA would work, do they split and provide enough length to go to two different amps? Or do I need two 2 chanel RCA's? one for L and R channels for the front stage and the other for the sub? do I even need a 2 channel RCA for the sub amp, is there such thing as a mono cable?
I also need a remote wire, or do I need 2, one for each amp?eloplayspolo wrote: »http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-22D (if ur going to run 2 amps)
i would go with 2 sets of rcas, 1 for each amp.
the speaker wire is wound 1 positive and 1 negative on that. u just need 60 then.....
BIG ADVISE! u alllllllllways need more than u think, especialy if ur going to biamp.
and also in the picture u have ur grounds in the same spot.... use 2 diffrent locations.2013 Toyota Prius
Mosconi 6to8 v8 -
I personally used different remote wire for my sub amp than my inside speakers amps. I use a switch on the remote wire thats lets me turn the sub amp on and off. I can use that feature with hy HU but I dont like navigating through the menu to get to that. It comes in handy when the cops are around, lol. But u can run two or run one and then splice it into two in the back to run to each amp. If you want to put an on/off switch you would need to run two.
Cool, thanks!
how about battery terminals? do I need them or do I just attach to the OEM terminal with the ring terminals?
I also just remembered that I have an old 1.5 farad cap, generic brand with a volt meter. think I should bother using it, I hear they are pretty pointless.
thanks again!eloplayspolo wrote: »i would go with 2 sets of rcas, 1 for each amp.
and also in the picture u have ur grounds in the same spot.... use 2 diffrent locations.HU: Clarion DRZ9255 4 Way Active:
Can I use any wire? I don't see them on knukonceptz.com?
thanks!I personally used different remote wire for my sub amp than my inside speakers amps. I use a switch on the remote wire thats lets me turn the sub amp on and off. I can use that feature with hy HU but I dont like navigating through the menu to get to that. It comes in handy when the cops are around, lol. But u can run two or run one and then splice it into two in the back to run to each amp. If you want to put an on/off switch you would need to run two.HU: Clarion DRZ9255 4 Way Active:
Are you buying an amp kit or are you buying everything seperate?
I was planning on buying everything seperate simply because my battery is in my trunk and I don't need 15+ft of power cable. a kit might be cost effective though, I'm not really sure. also, none of the brands I've looked at have dual 1/0 gauge amp kits.Are you buying an amp kit or are you buying everything seperate?HU: Clarion DRZ9255 4 Way Active:
IrishChamp wrote: »I was planning on buying everything seperate simply because my battery is in my trunk and I don't need 15+ft of power cable. a kit might be cost effective though, I'm not really sure. also, none of the brands I've looked at have dual 1/0 gauge amp kits.
http://www.sonicelectronix.com/cat_i142_0-2-gauge.html
check this site out. I buy alot of car gear from here, they are authorized dealers of a lot of brands and they have very good prices. I don't know what price range your in for amp hook up needs, but they have some reasonable priced amp kits with 1/0 guage, but i think you might have to purchase the RCA's seperate.
