Tube amp math
zingo
zingo Posts: 11,258
edited October 2008 in Electronics
I need the mathematical justification for why it is bad to run a tube amp without a load. I know it's a strange request, but can anyone help?
Post edited by zingo on
  • unc2701
    unc2701 Posts: 3,587
    edited October 2008
    No load means that when the High voltage side on the output transformer swings there's nothing pulling the generated EM field off, so it goes from being a transformer to being an electromagnet. It'll melt the primaries in your output tranny... but I think this is usually just a guitar amp phenomena- most home audio gear has protection circuits.
    Backburner:Krell KAV-300i
    mhardy6647 Posts: 34,959
    edited October 2008
    Here's a pretty good explanation in this PDF from One Electron:
    http://www.one-electron.com/Trans/UBT2_10.pdf
    to wit: "As with any output transformer, the UBT-2 [transformer] should always have a load connected when driven. If there is no load and the output tube is over-driven, the high inductance of the primary will cause extremely high voltages to be produced, damaging either the output tubes or the transformer."
    Where it gets tricky is that "over driven" statement. In some amps, this is (so to speak) a self-inducing condition. Some amps will self-destruct OPTs and or output tubes within seconds of no-load operation; others don't really seem to mind at all. I suspect it is related to the amp's architecture and specifically the amount and or execution of negative feedback. I am just guessing, though.
    EDIT: Take a look a the "feedback" section of this page on a simple little series-circuit amplifier from the late, great Fred Nachbaur's website: http://www.dogstar.dantimax.dk/tubestuf/4x4howit.htm
  • zingo
    zingo Posts: 11,258
    edited October 2008
  • I-SIG
    I-SIG Posts: 2,243
    edited October 2008
    Sounds almost like a ferroresonant condition.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
