Need Help!! Schematics
curved
Here is the deal.....I currently have a Sansui AU-6600 that's been in my family for a long time. I let my sister use it for a while and she blew a channel (or so she said). I popped the top on it and look inside - it has two internal fuses (both 1 amp and need to be matched). One of them was blown.....so I went to get a fuse - couldn't find one as I was way up north. When I got back, my dad had it closed up and said he had an extra one lying around....so he put it in. We turned it on and pffffffft!! One of the caps blew right next the fuse. He had used a 2amp instead of a 1 amp.
My problem is, I don't know what the hell that value was. I do have a copy of the schematics.....
HELP!!!
HELP!!!
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
Pre - Nak CA-5
BR - LG BD390
Post edited by curved on
Here it is - boy it made a mess!!:eek:Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
**Dayton and Sonicap Caps with Mills Resistors** -
There is a problem other than the cap. Check over at diyaudio.comPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Take it to someone who specializes in vintage audio gear. You probably do have something that went bad in one channel. Often, when one component goes, it takes out several other components too. Now that your dad put an oversized fuse in it, it probably damaged even more.
Best bet for that old amp is a full restore. Re-cap the whole amp, fix the problems, and adjust for proper output.
You might also want to check around over at Audiokarma.org. They have an extensive Sansui following over there and there are several repair technicians who are members there and could possibly offer advice.For rig details, see my profile. Nothing here anymore... -
Perfect!! Appreciate the quick responses. I actually just called a local place and they were going to charge me $30 to look at it....didn't think that was too bad. They were one of the only places I've found that works on Sansui.
If I get this up and running, it would be perfect for a 2-channel rig!!Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
$30 is cheap;)
Leave the cover off, and blow that thing out with some air. The less they have to play with, and some cleaning shows you care.
Ben -
I feel better about taking it in.....
It was actually pretty clean until that cap blew - it made a mess:eek:Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
$30 to look at it, not to fix it.____________________
Pool: Atrium 60's/45's -
$30 to diagnose the problem and tell me whats wrong with it. But as others stated, I'll probably have them re-cap the whole thing.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
I figured you knew that already-I can't tell you how many times, way back in the day, when I worked the tech shop at CUSA, how many customers thought the diags charge would be all that was required to fix it.____________________
$30 is still cheap for a diagnoses. I had price quote of $200 for a old Proceed CDP. :rolleyes:"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
