Speakers and Amps (OHMS?)
inmate-
inmate- Posts: 36
edited October 2008 in Speakers
okay i want to get a 6x9 and a 6x1/2 speakers that are about 120 wRMS (Both 4 OHM)
now... for the amp.. can i use a 4 ohm amp or a 2 ohm amp..? (2 channels ofcourse)
please help?
Post edited by inmate- on
  • inmate-
    inmate- Posts: 36
    edited October 2008
    anyone..? please
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited October 2008
    Speakers have resistance that is measured in ohms. If 2 4ohm speakers are wired together in parallel on a single channel, it will look like 2 ohms to your amp.
    In this case, you need an amp rated to run at 2 ohms.
    This is a sparse/simple answer to a more complex situation, but I hope it helps.
    mhardy6647 Posts: 34,020
    edited October 2008
    wire 'em in series, and they're an 8-ohm load.
  • Dennis Gardner
    edited October 2008
    I vote for a 4 channel amp so you can control the output of each speaker.
  • curved
    curved Posts: 664
    edited October 2008
    I think you should just get a 4-channel amp. I think it would sound better. I never like to run my "full-range" speaker at 2 ohms. The THD (total harmonic distortion) is generally a lot higher at 2ohm vs 4ohm
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • inmate-
    inmate- Posts: 36
    edited October 2008
    does this also apply to 2x channels amps
    Im not sure if i created confusion.. but im trying to get 2(pairs) of speakers that are at 4 ohms.. (a total of 4 speakers... but like 2 pairs)... could i run them with a 2 ohm load from the amp?
  • Dennis Gardner
    edited October 2008
    You can run them from a 2 channel amp, but again, you don't have any balance control between them.
    I assume that the 6X9s are rears and the 6.5s are fronts. This setup needs a way to balance/fade between them, and separate amp channels for each speaker is the best way to accomplish this.
  • inmate-
    inmate- Posts: 36
    edited October 2008
    so i would need a 4 channel amp ... at how many ohms each channel? 4?
  • Dennis Gardner
    edited October 2008
    Any 4 ohm rated amp will do. Most car amps are rated to 4 ohms since most car speakers are 4 ohm. An amp rated for 2 ohms or lower is typically an indication of solid build quality since the lower load requires the amp to make more power.
  • curved
    curved Posts: 664
    edited October 2008
    Here is MY rule of thumb for car audio:
    -All of my components I run in 4ohm - If the amp is 4 channels, I would be powering 4 - 4ohm speakers. They generally don't need as much power (but you do want clean power)
    -With subs, I usually like to bridge them as they need a lot more power. Distortion is harder to hear with subs (car audio) so running an amp at 2ohms usually fits the bill quite nice.
    Pre - Nak CA-5
    BR - LG BD390
  • zingo
    zingo Posts: 11,258
    edited October 2008
  • curved
    curved Posts: 664
    edited October 2008
    zingo wrote: »
    So that's how your post count is so high;) jk
    Pre - Nak CA-5
    BR - LG BD390
