Klipsch KSW-300
KrazyMofo24
I just picked up this sub at a garage sale for $100, have not had a chance to hook it up yet. I currently have the LSi7's, I was wondering if anyone has had any experience on this sub, and if it'll go well with Lsis.
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
Post edited by KrazyMofo24 on
KrazyMofo24 wrote: »I just picked up this sub at a garage sale for $100, have not had a chance to hook it up yet. I currently have the LSi7's, I was wondering if anyone has had any experience on this sub, and if it'll go well with Lsis.
It's an old Klipsch sub.... precursor to the KSW-15.
It's not BAD, it'll go fairly low, i just didn't feel that it was too fast or accurate, but that may have been placement when i last heard one. I WILL say that it'll shake stuff pretty well.
They had an issue with these shaking stuff loose inside, so you may have to mess with it a little if you have a rattling problem.
For $100, if it's in good shape, i think you did pretty well. I enjoyed mine when i had it, but my current RW-10D blows it out of the water (and costs more than what you paid) so i'd consider it a decent trade-off.
Let us know what you think.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Good sub for HT - nice pickup!!
You may like it with your LSi7's - let your ears be the test and report back to us
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Thanks for the responses. I have been doing without a sub for quite sometime, so far I am pleased with it. I have not tried on a blue ray movie yet, but the bass sounds good enough for me, and its made a pretty good improvement on my setup.
I am still debating on what my next upgrade will be. I have the lsi7's powered on HK 3385. I still feel the speakers can sound better I still need a center channel and want to get the LSi15's and a better sub eventually.
What would you guys recommend I upgrade next? I am still on a budget so still have to get things one at a time, unless I make some money playing poker.
I have ls7's as mains powered by HK 3385, and the H/k avr 335 powering the Fxi5's and the new sub. I am leaning towards a better amp, something will be able to power the Lsi15's later.Setup:
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
It depends what you mostly use your system for.....if you do a lot more of HT, you may what to invest in a center.....but if you do listen to a lot of music, I would go with an amp....
Personally, I would go with an amp.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
I am leaning towards an amp too, but I know the next amp I get I want it to be a good one. I want to be able to not just be good enough for the LSi7's but also for a new pair of floor standers when I upgrade later for that. I guess I'll need to do some research on amps.Setup:
