Martin Logan Abyss Problem
I have a Martin Logan Abyss sub for my bedroom. This sub has been great for over a year but recently I’ve noticed that the sub was not working properly. I’d get no sound from the sub, at first I would just turn the sub off and turn it back on and problem fixed...great sound. Now I’m getting to me what sounds like feedback from the sub a low humm. I think just maybe I got a wiring problem from my receiver to the sub. Just wanted to know if anyone else has this problem and the correct fix.
Bedroom Stuff 5.1
Pioneer Elite VSX-82TXS
Pioneer Elite Blue Ray BDP-05FD
Monster Power HTS3500
Harmont Remote 880
Sony Bravia KDL40S2400
Polk RTi8's Front
Polk T20E's Rear
Polk RM202 Center
Martin Logan Abyss Sub:D :D ::D
Basement Stuff 7.1
Sony STR ES5000
Sony DVD NC55ES
Pioneer Elite DVD DV48AV
Pioneer Elite 910HD
Monster Power HTS3600
Harmony Remote 688
Warfedale Diamond 8.4 Front
Warfedale Diamond 8.2 Sides & Rear
Warfedale Diamond 8 Center
SVS PB12-Plus/2 Sub:D:D :D
Post edited by harold280z on
  • shawn474
    shawn474 Posts: 3,047
    edited October 2008
    I would try to replace your subwoofer cable first.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • curved
    curved Posts: 664
    edited October 2008
    Any updates?? Did you check the connection to the back of your AVR or see if the sub cable is "pinched" anywhere?
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • harold280z
    harold280z Posts: 72
    edited October 2008
    Thanks it was the sub cable...I a bad cable, replace it and all is well!:)
    Bedroom Stuff 5.1
    Harmont Remote 880
    Polk RTi8's Front
    Polk T20E's Rear
    Polk RM202 Center
    Basement Stuff 7.1
    Sony STR ES5000
    Sony DVD NC55ES
    Pioneer Elite 910HD
    Harmony Remote 688
