Walsh Ohm 2 Value?
cmy330go
cmy330go Posts: 2,341
edited October 2008 in Vintage Speakers
I have a guy locally that is selling a set of Walsh Ohm 2 speakers. They appear to be in really good shape. Just curious if someone could tell me what would be a fair price for them. Also is there any known issues with these that I should be aware of? And I guess most importantly.... Are they worth having?:confused:
Thanks.
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
Post edited by cmy330go on
  • thebluemonkey
    thebluemonkey Posts: 190
    edited October 2008
    I paid $40 for a excellent pair out of the local paper
  • cmy330go
    edited October 2008
    Nice.
    Does anyone have a bluebook that they could check for me?
    HT
    2 CH
    mhardy6647 Posts: 35,229
    edited October 2008
    Nice speakers. I wouldn't hesitate to pay $100 or even $150 for a pair in good condition.
    I do not think that the surrounds on the (mini) Walsh drivers on those will be foam... that's really the only thing to worry about. These are much smaller, cheaper, more efficient, and less persnickety than the "real" Ohm Walshes (e.g., Ohm Walsh F).
    I have a pair of the small Ohm Walshes... not that I have ever figured out which model they are.
    The small Ohm Walsh drivers are basically just inverted speaker cones (these also have 'helper' tweeters)... but they do sound quite nice if a bit diffuse relative to direct radiators.
  • nadams
    nadams Posts: 5,877
    edited October 2008
    Just FYI- you two may be looking at the same speaks - http://www.polkaudio.com/forums/showthread.php?t=73608
    Ludicrous gibs!
  • cmy330go
    edited October 2008
    Yea I think you're right. I wasn't aware they were listed.
    HT
    2 CH
