interconnect cable
Cthulhu11
Cthulhu11 Posts: 69
edited October 2008 in Speakers
Hello, i have not a difficult question, just a question i can't seem to find the answer to , i just purchased a pair a SDA-1c and got original box and everything except the interconnect cable, i know i can purchase one from ebay or polk but i would like to make one what do i need to make my own??
  • Ricardo
    Ricardo Posts: 10,634
    edited October 2008
    Hi and welcome to the forum; the SDA 1C probably has a pin-blade connector. These are NOT available from Polk, though you could find one on ebay.
    All you need is to connect the pins; the blades are not required for the normal interconnect. Just use any cable and stick it in there.
    I guess you know that you need a common ground amp to drive them...if not, then now you do :)
    SOPA
