Speaker cable boxes?
NJPOLKER
NJPOLKER Posts: 3,475
edited October 2008 in Vintage Speakers
I am thinking I may get a better response here than where I first posted it in Hook Ups Connections thread.
What are in the boxes used by the high end speaker cables? Gotta be gold based on the costs!
Thanks Drew
Example
http://www.audiogon.com/cgi-bin/cls.pl?cablspkr&1228539477&/MIT-Shotgun-S2-BiWire-10'-Pair
Post edited by NJPOLKER on
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited October 2008
    There is magic inside those boxes:D
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • NJPOLKER
    edited October 2008
    I am expecting someone to tell me to buy a pair and open them up if I am so curious.
    F1nut Posts: 51,922
    edited October 2008
    What Scott said and I'll add, it doesn't matter what's in them. It's what comes out at the speaker end, which is glorious.
  • NJPOLKER
    edited October 2008
    Yeah Yeah Yeah but whats in them? Ya gotta know. There is no way the folks around here don't know whats in them!
  • ben62670
    ben62670 Posts: 15,969
    edited October 2008
    NJPOLKER wrote: »
    If you buy me a set I'll tell you what's inside:)
    Ben
  • NJPOLKER
    edited October 2008
    I feel like a f ing dentist here.
    Oh well
    I think it was the Rolling Stones You Can't Always Get What You Want
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited October 2008
    You actually got an answer in your original post as to what's in Transparent's speaker wire box.
    There were a couple of sites with pictures of what was inside. A Vishay 26.7 ohm resistor and a 0.001uF capacitor. Total parts cost of less than $1.50.
    F1nut Posts: 51,922
    edited October 2008
    Bah humbug to you too.
    He was talking about MIT cables and I can assure you, they are nothing like Transparent cables, not to mention that the ones you refer to are very old examples.
  • WilliamM2
    edited October 2008
    Why the attitude? I just told him what was in them.
    He may have used MIT as an example, but here was his question:
    Also, how can you assure me that the MIT's are nothing like the Transparents? Have you opened your's up? If so, please answer his question.
    F1nut Posts: 51,922
    edited October 2008
    William, it's a well known fact that you don't believe in cables. All I did was acknowledge that fact.
    Yes, I have seen more current photos of the insides. No, I have not opened mine. If I could tell you all that is inside an MIT network box I would, but I can't. What I can tell you is that MIT has a lot more stuff than Transparent has inside theirs. MIT also holds considerably more patents than Transparent.
    The bottom line here is that for the many of us who have tried MIT cables, that they do work magic. If it makes a difference to anyone, Matt Polk also thinks MIT cables are excellent.
  • ben62670
    edited October 2008
    WilliamM2 wrote: »
    You wouldn't happen to have any links would you?
    Ben
    Ben
  • WilliamM2
    edited October 2008
    I have a link, but it's 4 years old, and the pics are no longer up. It's also in Swedish:
    http://www.faktiskt.se/modules.php?name=Forums&file=viewtopic&t=2953&postdays=0&postorder=asc&start=0
    I'm sure if you Gogle it, you can find more info.
  • ben62670
    edited October 2008
    Thanks Bill.
    Google isn't too much help. Most who can afford MIT's aren't too into DIY I guess. Basically what I can see is they are impedance matching with the R, and C going across from Pos to Neg. I'll do some calculations to see what .001uf, and 26.7r equates to. What I am speculating is the values are designed to offset the C, I, and R of the wires themselves to remove the possibility of the speaker wires coloration.
    Ben
    Ben
    heiney9 Posts: 25,490
    edited October 2008
    I just upgraded to MIT's with the "box" and the results were extremely favorable. After participating in Ricardo's MIT cable swap and having a chance to demo them in mys system I went out and bought a used pair.
    Mine are along the entry level of MIT cables but I am very very pleased I made the jump. The great thing about MIT is if you get them and don't like them you probably won't loose anything more than the shipping cost if you flip them.
    Seems like a no brainer to me ;)
  • WilliamM2
    edited October 2008
    ben62670 wrote: »
    Thanks Bill.
    Ben
    They are wired as a Zoebel network. Shouldn't affect frequency response at all.
    Would work well for impedance matching as well, if the manufacturer had any idea what amps and speakers you were using, and designed them specifically for that setup, which of course they don't.
  • Face
    Face Posts: 14,340
    edited October 2008
    That's why the impedance boxes are adjustable.
