LSI Center speaker
I recently bought a LSI Center speaker. The speaker is supposed to be run at 4 ohms. I have a Yamaha receiver model rx-v2300 which only supports 8 or 6 ohms. I turned the receiver to 6 ohms. Is it o.k. to run this speaker at 6 ohms or will it damage it. My system is a 6.1 I have the LSI as my center, mains are RTi 800's, rear's are F/X i30's and my rear main is a CSI 40. Also I recently purchased RTi's for the mains and the right speaker seems to be making noises as if the driver is blown. Is it difficult to replace the drivers on this speaker. I never did it before. I imagine you can buy replacement drivers from Polk. Is that correct. Thanks.
Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
Post edited by bluecomet on
Welcome to the forum.
Like Sal said you will be OK unless you crank the volume. What sound level do you like to listen? It might be a wise to purchase a muliti-channel amp to power your Front speakers and center channel.
Jim -
Thanks for the replies. I will keep the volume down so I don't blow anything. Anybody have experience with changing drivers.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
