Outlaw LFM-1 Subwoofer
schwarcw
Polkfest Special!
I will have this Outlaw sub with me this weekend!
For Sale: Outlaw Audio LFM-1 Plus Subwoofer, designed by Dr. Hsu for Outlaw Audio. Excellent condition,only 2 years old. Excellent sound! Was $500, sell for only $400, including 10M Outlaw Subwoofer cable (worth $129.95)
See specs, below.
The LFM-1 Plus takes our highly acclaimed LFM-1 Subwoofer to the next level. A new more powerful amp, special EQ, and custom port plug combine to deliver an amazing 18Hz while maintaining a linear response right across it's audible bandwidth. Now, you no longer need to sacrifice low frequency extension to maintain that smooth "true to the original" sound of your favorite recordings.
Among the LFM-1's many features are:
• A down firing design that virtually eliminates audible port noise
• A long throw 12" driver for deep bass extension
• A powerful 350 watt BASH® amplifier for precise driver control
• Variable port tuning for customized output
• Signal Sense for automatic turn on/off
• 180-degree phase control
• Line and speaker level inputs
• Detachable power cord
Specifications
Driver Type: Down Firing, 12" Long-throw Woofer
Ports: Dual
Amplifier Power Rating: 350WRMS; 1300W peak
Frequency Response: 25Hz. -180Hz. +/- 2 dB w/o Port Plug
18Hz.-180Hz +/-2dB w/ one port plugged
Crossover Type: Linkwitz-Reily 4th Order Low Pass Network
Crossover Frequency: 40Hz to 180Hz and Bypass
Phase: 0 to 180 Degrees
SPL: 115dB (subject to placement and room gain)
Dimensions: (HxWxD) 21.75" x 15.0" x 22.0"
Weight: 70 lbs
Stock Image:
See specs, below.
Specifications
Ports: Dual
Weight: 70 lbs
Stock Image:
Carl
Post edited by schwarcw on
Great sub! I used to have one.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
