Ebay SL1000 CRS+
zingo
zingo Posts: 11,258
edited October 2008 in Vintage Speakers
I just found these on ebay and they have the SL1000 tweeter if I'm not mistaken. It looks like a bit of a hack job as you can see the SL1000 bezel is not exactly the same size and the SL2000 bezel. They come with the IC, but I can't tell if they are B-B or P-B.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150303805531&indexURL=2&photoDisplayType=2#ebayphotohosting
Post edited by zingo on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2008
    He ended auction early
  • ben62670
    ben62670 Posts: 15,969
    edited October 2008
    Peerless
    Ben
  • zingo
    zingo Posts: 11,258
    edited October 2008
    They made a Peerless that didn't have a hole in the middle?
  • jtgranby
    jtgranby Posts: 887
    edited October 2008
    I have never seen a SDA CRS+ with peerless tweeters.
    Jim
  • zingo
    zingo Posts: 11,258
    edited October 2008
    You are correct sir! (Thus my post)
  • Face
    Face Posts: 14,340
    edited October 2008
    zingo wrote: »
    Yes.
  • zingo
    zingo Posts: 11,258
    edited October 2008
    I stand corrected. What was the difference between the two Peerless tweets?
  • ben62670
    edited October 2008
    Holes
    Ben
  • ESavinon
    ESavinon Posts: 3,066
    edited October 2008
    Peerless without holes had a ringing problem. The hole in the middle took care of that.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
