Trigger Cable?
wingnut4772
I need to pick up a couple of these but they are not listed under' 12volt trigger cable'. What am I looking for?
TIA
TIA
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
What kind of connections are on your amps, etc...either RCA or 1/8". Radio shack should have what you need."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
It is usually a 1/8" dubbing cable (male to male).
http://www.radioshack.com/product/index.jsp?productId=2103841&cp=&sr=1&kw=dubbing+cable&origkw=dubbing+cable&parentPage=search -
I have no idea what kind.:pIt is usually a 1/8" dubbing cable (male to male).
Thanks.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Yeah that's it. But word to the wise Darla, I had to stop using mine, it started shutting off my prepro without warning. I would have to turn it off & back on to get it back. Once I took off the cable the shutting down stopped happening.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
wingnut4772 wrote: »Wingnut's Home Theater/2 Channel
I'm excited to see the new setup when it's finished Darla! -
It's slowly getting there. Getting my amp and my Panamax 5300 tomorrow. Surround stands still on back order....Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
RTFM... :eek:wingnut4772 wrote: »I have no idea what kind.:p
Thanks.
It can be either. Half my gear uses 1/8", the rest RCA. Look in the manual or on the back of your gear. If it looks like a headphone jack, it's 1/8", if it's a RCA, then...
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
RTFM... :eek:
Why can't it just all be one standard thing?:DSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
picked up a few at monoprice last week
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10218
